Anker Soundcore Motion Boom Plus Motherboard Replacement
  1. Anker Soundcore Motion Boom Plus Motherboard Replacement, Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement, Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement, Case: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert an opening tool into the seam between the speaker grille and the chassis.
    • Pry the tool around the top, bottom, and sides until the grille fully releases.
    • Apply gentle pressure to avoid damaging the grille.
    • Remove the grille.
  2. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two passive radiators on either side of the device.
    • Avoid pulling too hard or with too much force to prevent breaking the passive radiators.
  3. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the sixteen 14 mm Phillips screws, eight on each end of the speaker.
  4. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the handle from the device by clicking off the handles from the sides and then pulling it off.
  5. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the speaker onto its side and use a spudger to remove the two rubber feet on the bottom of the device.
  6. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eleven 13 mm Philips screws that secure the driver housing.
  7. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 14 mm Phillips screws located on each side of the handle, near the clip points.
  8. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the four 14 mm Philips screws on the top of the device.
  9. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert a spudger into the seam on top of the device.
    • Gently pry the casing open.
  10. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect each of the three cables by gently pulling the connectors out of their sockets.
    • Do not pull with force. The ribbon cables are fragile and easily break.
  11. Anker Soundcore Motion Boom Plus Motherboard Replacement, Motherboard: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement, Motherboard: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement, Motherboard: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three 12 mm Phillips screws securing the motherboard to the chassis.
    • Remove the two 10 mm Phillips screws surrounding the battery.
  12. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the speaker over and push the charging port inward.
  13. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the motherboard and battery out by pushing through the charging port.
    • The motherboard and battery assembly should detach easily.
  14. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 10 mm Phillips screws securing the motherboard and battery together.
    • Gently lift the motherboard from the battery once all screws are removed.
    • Handle with care to avoid damaging any of the components.
  15. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the motherboard and battery apart.
  16. Anker Soundcore Motion Boom Plus Motherboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Reconnect the new motherboard to the battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Hayley
crwdns2935283:003/26/25crwdne2935283:0
988 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 3-7, Botvin Spring 2025 crwdns2935289:0UMass Dartmouth, Team 3-7, Botvin Spring 2025crwdne2935289:0
UMASSD-BOTVIN-S25S3G7
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 61
