Anker Soundcore Motion 300 Drivers Replacement
    1. Anker Soundcore Motion 300 Drivers Replacement, Speaker Grille: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Motion 300 Drivers Replacement, Speaker Grille: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Insert an opening tool into a seam between the grille and chassis.
      • Gently pry the grille up to begin disengaging the retaining clip.
      • Once a corner starts to lift, slowly slide the tool along the edge to loosen more of the grille.
    2. Anker Soundcore Motion 300 Drivers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anker Soundcore Motion 300 Drivers Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Keep working around the edges until all the clips are loose.
      • You may hear soft clicking sounds as the clips come undone.
    3. Anker Soundcore Motion 300 Drivers Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Carefully remove the grille from the speaker.
    1. Anker Soundcore Motion 300 Drivers Replacement, Drivers: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion 300 Drivers Replacement, Drivers: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion 300 Drivers Replacement, Drivers: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Phillips #0 screwdriver to remove all eight 11.5 mm screws that secure the driver housing.
    2. Anker Soundcore Motion 300 Drivers Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion 300 Drivers Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion 300 Drivers Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use an opening tool to pry up the speaker housing.
      • Set the speaker housing beside the speaker, with care not to strain the cables connected to the drivers.
      • The speaker housing may be very difficult to remove due to adhesive. If necessary, use a hairdryer to lightly heat the perimeter of the housing to loosen the adhesive.
    3. Anker Soundcore Motion 300 Drivers Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion 300 Drivers Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anker Soundcore Motion 300 Drivers Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • With a Phillips #0 screwdriver, remove the four 7.5 mm screws that secure the driver.
      • Repeat the previous bullet for the other driver.
      • Gently lift off the drivers; the speakers may be slightly glued or stuck to the plastic plate so try not pull on the wiring attaching the components.
      • Disconnect each of the the two driver connectors from the motherboard.
      • There may be a small piece of sealant that must be removed before the connectors can be removed.
      • Remove the drivers.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Holly Hoffman
crwdns2935283:002/17/25crwdne2935283:0
487 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 1-2, Sneed Spring 2025 crwdns2935289:0University of Memphis, Team 1-2, Sneed Spring 2025crwdne2935289:0
UM-SNEED-S25S1G2
crwdns2936753:030crwdne2936753:0 94
crwdns2942667:0crwdne2942667:0 718
