This is a simple guide on the replacement of the speaker within the Anker SoundCore 2. You may need to replace the speaker if it will not play at all, if there is sound delay, or if the speaker has blown out. Take a look at our troubleshooting page to see if you need to replace your speaker or not.
Insert a spudger between the front panel and the body of the speaker.
Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
Use your hand to remove the speakers.
The speakers do not use wires so when replacing the speaker, make sure you align the metal prongs with the metal clips on the motherboard.
Where can i find the replacement speaker for anker soundcore2. Please send me the link
Also need the same for me.
I need genuine or good speaker that fits in it.
Any replacement speaker for this model?
crwdns2947412:011crwdne2947412:0
Excellent guide, my speaker falls to the ground, and one of two speaker stops working, disassemble and verifying, was the speaker clip was loose
Where can I buy a speaker for the repair ? Or will any sized speaker work ?
hi, did you manage to buy a replacement speaker? If yes from where pls?
jafarez -
Do someone get a new speaker? I need to buy one!
jafarez -
where can i buy a pair of speakers of it ?
Where can I buy speakers OF anker soundcore select 2?
I need a pair of it
Where can I buy the speaker,am in Nigeria
Speaker source please?
Anchor bluetooth speaker ke
Where can i buy a pair of speaker?
How do i put the front plate back on
Hardstarling - crwdns2934203:0crwdne2934203:0
