Use this guide to replace the left and right mouse buttons on your Anker 2.4G Wireless Mouse.
A mouse button is an electrical switch on the mouse which allows a user to interact with a graphical user interface. They will eventually wear out through continuous use. If you notice the left or right mouse button not working properly all of the time, you may need to replace the left or right mouse button.
Please be sure to check out the troubleshooting page before using this guide. Often times, malfunctioning mouse buttons are a software issue and can be fixed without replacing the left and right mouse buttons.
Step 7 in this guide requires you to desolder the mouse buttons and solder new ones in place.
Make sure that the mouse is turned off before starting.
Peel off the stickers. This will reveal the location of four screws.
Remove the four screws using a Phillips #0 screwdriver.
Use a spudger to pry apart the upper and lower housing of the mouse.
Pull the wires from the white crimping headers to disconnect them. This separates the top housing from the bottom housing.
Remove the scroll wheel from the mother board by pulling it to the left.
Pull the mother board gently away from the plastic housing.
Desolder the components and re-solder the replacements in order to repair the left and right buttons.
i bought the same mouse on amazon the same day i got it stopped working and anker was out of stock so i couldn't get another one directly from them, plus i really like it i opened up the mouse using your step by step and found the issue.
where can these replacement button switches be purchased….thanks ric
