Anbernic RG35XXSP Motherboard Replacement
  1. Anbernic RG35XXSP Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Motherboard Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power the device off before starting the disassembly process.
    • Close the device and flip it so the bottom is facing up.
  2. Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the single 5 mm screw securing the battery cover.
    • Lift the battery door and remove it.
  3. Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T6 Torx screwdriver to remove the four 5 mm screws.
    • Lift the whole back case with the battery up from the device.
    • Don't pull it away because the battery is connected to the board.
  4. Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery from the back compartment and fit it through the gap in the back case.
    • Put the plastic case aside for reassembly.
  5. Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pinch the sides of the battery connector and slide it from the socket to disconnect the battery cable.
    • Remove the battery.
  6. Anbernic RG35XXSP Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG35XXSP Motherboard Replacement, Motherboard: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the green sheet of paper from the motherboard.
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws from the motherboard.
  7. Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be careful when moving the motherboard as it is connected to the display ribbon cable, and can be damaged if pulled on.
    • Pick up the motherboard and flip it over.
  8. Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Motherboard Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger or a clean fingernail to flip up the black locking flap—this is the unlocked position.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the display cable out of its socket.
    • Remove the motherboard.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Daniil Kim
crwdns2935283:001/15/25crwdne2935283:0
916 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-2, Kilpatrick Spring 2025 crwdns2935289:0University of North Texas, Team 1-2, Kilpatrick Spring 2025crwdne2935289:0
UNT-KILPATRICK-S25S1G2
crwdns2942667:0crwdne2942667:0 60
