Anbernic RG35XXSP Action Buttons Replacement
  1. Anbernic RG35XXSP Action Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power the device off before starting the disassembly process.
    • Close the device and flip it so the bottom is facing up.
  2. Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the single 5 mm screw securing the battery cover.
    • Lift the battery door and remove it.
  3. Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T6 Torx screwdriver to remove the four 5 mm screws.
    • Lift the whole back case with the battery up from the device.
    • Don't pull it away because the battery is connected to the board.
  4. Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery from the back compartment and fit it through the gap in the back case.
    • Put the plastic case aside for reassembly.
  5. Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pinch the sides of the battery connector and slide it from the socket to disconnect the battery cable.
    • Remove the battery.
  6. Anbernic RG35XXSP Action Buttons Replacement, Action buttons: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement, Action buttons: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the R2 button and gently lift it to remove it.
    • Pinch the R1 button and gently lift it to remove it.
    • You will have to pull a little harder as it has a plastic pin that is connected to the body.
  7. Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the L2 button and gently lift it to remove it.
    • Pinch the L1 button and gently lift it to remove it.
  8. Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to pull the power & reset buttons up from the side of the device
  9. Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the volume buttons from the side of the case.
    • The plus side of the buttons should be closer to the back of the device.
  10. Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the green paper sheet from the motherboard.
    • Use a Phillips #00 screwdriver to remove the three 5 mm screws from the motherboard.
  11. Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the motherboard over to reveal the action and directional buttons.
    • Remove the action and directional button gaskets from the motherboard.
    • In some cases, the gaskets may get stuck in the plastic case. If this happens, you can still take out the buttons like normal.
  12. Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG35XXSP Action Buttons Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers to remove the directional buttons from the case.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Daniil Kim
crwdns2935283:001/15/25crwdne2935283:0
916 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-2, Kilpatrick Spring 2025 crwdns2935289:0University of North Texas, Team 1-2, Kilpatrick Spring 2025crwdne2935289:0
UNT-KILPATRICK-S25S1G2
crwdns2942667:0crwdne2942667:0 72
