Anbernic RG35XX Screen Replacement
  1. Anbernic RG35XX Screen Replacement, Rear Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG35XX Screen Replacement, Rear Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the SD card located on the right side of the device by pushing into the SD card slot and pulling the card out.
    • Remove the six 1.2 mm screws that secure the back case with a 2.5 Hex Bit screwdriver.
  2. Anbernic RG35XX Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert an opening tool into the MicroSD card slot and twist it clockwise to begin releasing the rear case.
    • You'll hear "clicks" as the retaining clips release.
    • Pry around the entire perimeter until the rear case fully releases.
    • Remove the rear case.
  3. Anbernic RG35XX Screen Replacement, Anbernic RG35XX Battery Disconnection: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Anbernic RG35XX Screen Replacement, Anbernic RG35XX Battery Disconnection: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingernails or tweezers to gently remove the battery connector from its socket.
  4. Anbernic RG35XX Screen Replacement, Motherboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the red audio cable from its motherboard port by carefully pulling the connector with your index finger and thumb or with fine tip tweezers.
  5. Anbernic RG35XX Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six 1 mm Phillips screws that secure the motherboard to the case.
  6. Anbernic RG35XX Screen Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anbernic RG35XX Screen Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anbernic RG35XX Screen Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip up the black ZIF locking flap that secures the bronze ribbon cable.
    • Gently disconnect the bronze ribbon cable.
    • Lift the motherboard up and out the chassis.
  7. Anbernic RG35XX Screen Replacement, Screen: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The wire is not part of the sticker.
    • Remove the black sticker on the back of the screen.
  8. Anbernic RG35XX Screen Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Anbernic RG35XX Screen Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Anbernic RG35XX Screen Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • The screen is attached with adhesive.
    • Do not heat the device too much, stop at regular intervals and insure that no pieces are being affected badly.
    • Use a hair dryer to gently heat the rear of the screen until it's almost too hot to touch.
    • Insert a jimmy between the screen and plastic bracket. Once a slim gap is opened, insert an opening pick between the plastic bracket and rear screen.
    • Reheat the screen as needed.
    • Continue to insert opening picks around the entire perimeter of the screen as you pry to avoid the adhesive from reengaging.
    • Once the screen fully releases, remove it.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Muhammad Mustafa Asim
crwdns2935283:008/28/24crwdne2935283:0
135 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 6-16, Kilpatrick Fall 2024 crwdns2935289:0University of North Texas, Team 6-16, Kilpatrick Fall 2024crwdne2935289:0
UNT-KILPATRICK-F24S6G16
crwdns2936753:07crwdne2936753:0 53
crwdns2936753:030crwdne2936753:0 191
crwdns2942667:0crwdne2942667:0 1,886
