Analogue Pocket Power and Volume Buttons Board Replacement
  1. Analogue Pocket Power and Volume Buttons Board Replacement, Prepare your device for disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Prepare your device for disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Prepare your device for disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug all cables and fully power off your device.
    • Working on your device requires laying it screen-side down. To prevent damage, lay it on a soft surface such as a towel.
  2. Analogue Pocket Power and Volume Buttons Board Replacement, Unfasten the battery shell: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Unfasten the battery shell: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T6 Torx screwdriver to remove the four 13.4 mm‑long screws securing the battery shell.
  3. Analogue Pocket Power and Volume Buttons Board Replacement, Remove the battery shell: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the battery shell: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the battery shell: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
  4. Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use blunt nose tweezers to pull the battery connector out of its socket on the bottom right corner of your device.
    • If you're having trouble, try rocking the connector side-to-side to help loosen it.
    • During reassembly, use the flat end of a spudger to push down on the edges of the connector until it's secure in the socket.
  5. Analogue Pocket Power and Volume Buttons Board Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the battery: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift one of the battery's short edges until the clips release.
    • Remove the battery.
    • During reassembly, push the battery into its recess until the clips engage.
  6. Analogue Pocket Power and Volume Buttons Board Replacement, Unclip the button board: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Unclip the button board: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Unclip the button board: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • A plastic clip secures the center of the button board.
    • Use the point of a spudger to push the clip out and release the board.
    • Don't try to remove the board—a delicate ribbon cable secures it to the device.
  7. Analogue Pocket Power and Volume Buttons Board Replacement, Reposition the button board: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Reposition the button board: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Reposition the button board: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Swing the bottom edge of the button board up and over the cartridge reader.
    • Set the board on top of the cartridge reader so the cable's connector is facing the bottom of the device.
    • During reassembly:
    • Put the top edges of the board under their tabs on the rear shell.
    • Lay the board onto the rear shell so the alignment posts go into their circular cutouts on the board.
    • Press the board down until the plastic clip engages.
  8. Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the button board: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the button board: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the button board: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the board cable ZIF connector located on the board itself.
    • Use blunt nose tweezers to pull the cable straight out of its socket.
  9. Analogue Pocket Power and Volume Buttons Board Replacement, Remove the board: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the board: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the board.
  10. Analogue Pocket Power and Volume Buttons Board Replacement, Unclip the rear shell: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Unclip the rear shell: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Unclip the rear shell: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Sliding tabs secure the perimeter of the rear shell.
    • Firmly grip your device with one hand.
    • With your free hand, lift the bottom edge of the rear shell until it clears the front shell.
    • Pull the rear shell down until the sliding tabs disengage.
  11. Analogue Pocket Power and Volume Buttons Board Replacement, Remove the rear shell: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the rear shell: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the rear shell: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the rear shell.
    • Thread the button board cable through its slot in the rear shell.
    • Lay the rear shell on the front shell so its bottom edge slightly overhangs.
    • This allows the tabs to slide into place. If the rear shell is perfectly flush with the front shell, the tabs won't slide.
    • Push the rear shell in and slide it up to engage the sliding tabs.
  12. Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the board: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the board: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Disconnect the board: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tip of a spudger or a clean fingernail to flip up the hinged locking flap on the power and volume button cable ZIF connector.
  13. Analogue Pocket Power and Volume Buttons Board Replacement, Remove the board: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the board: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Analogue Pocket Power and Volume Buttons Board Replacement, Remove the board: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Tesa 61395 Tape
    $5.99
    • Adhesive secures power and volume button board to the front shell.
    • Insert the point of a spudger between the motherboard and the left side of the button board.
    • Use the point of a spudger to push the button board out to separate the adhesive securing it.
    • Grip the board itself with blunt nose tweezers and remove it.
    • If you're reusing your board, the leftover adhesive should be sticky enough to adequately secure it.
    • If your new board comes with pre-installed adhesive, remove any linings and use a spudger to press the board into place.
    • If your board doesn't have adhesive or the leftover adhesive isn't sticky enough, use strips of thin double-sided tape such as Tesa Tape to secure it.
Spencer Day
crwdns2935283:009/14/22crwdne2935283:0
117,207 crwdns2915208:0crwdne2915208:0
crwdns2935297:0837crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020,909crwdne2935297:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 170
