Occasionally speakers start malfunctioning or stop working entirely. In this guide we show you how to replace those speakers and get your AmazonBasics BTV1 running again.
Hold the speaker firmly and wedge a plastic opening tool in between the faceplate and the body of the speaker.
Move the tool back and forth along the entire perimeter of the face plate until you feel the plate loosen, then pry the plate off.
Using a Phillips #1 screwdriver, remove the four black 10mm screws around each of speakers.
Using a Phillps #1 screwdriver, remove the four black 10mm screws securing the inside panel to the case.
Tilt the case downwards until the speakers fall out of their housings.
Reach your thumb and forefinger past the speakers and detach the front speaker panel from the unit.
Gently pull the two plastic connectors from the motherboard.
Lift the front panel of the case and remove the speakers.
Where do you get replacement speakers? What kind?
