Amazon Luna Controller Shell Replacement
  1. Amazon Luna Controller Shell Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the controller over so that the back panel is facing up.
  2. Amazon Luna Controller Shell Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Luna Controller Shell Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Luna Controller Shell Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the latch on the back panel.
    • Pull down gently to open the compartment and expose the battery slots.
    • Remove batteries.
  3. Amazon Luna Controller Shell Replacement, Faceplate: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the controller over to its front and locate the seam where the front plate connects to the rest of the body.
  4. Amazon Luna Controller Shell Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Hold the controller firmly.
    • Insert the thin edge of an iFixit opening tool into the seam at the edge of the front plate close to the A button.
    • Work slowly and carefully around all sides to avoid snapping the clips.
  5. Amazon Luna Controller Shell Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Luna Controller Shell Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all clips are released, lift the front plate away from the controller.
  6. Amazon Luna Controller Shell Replacement, Buttons: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Luna Controller Shell Replacement, Buttons: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the six 8 mm screws securing the controller's body using a TR9 Torx screwdriver.
  7. Amazon Luna Controller Shell Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Luna Controller Shell Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry along the seam that separates the two halves of the controller using an opening tool.
    • Work your way around the perimeter to carefully release the clips securing the two halves.
  8. Amazon Luna Controller Shell Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Luna Controller Shell Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Luna Controller Shell Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lay the front of the controller shell downward.
    • Remove the rubber padding that keeps the buttons in place.
    • Remove the buttons from the shell housing.
  9. Amazon Luna Controller Shell Replacement, Joystick Cover: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Luna Controller Shell Replacement, Joystick Cover: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the joystick thumbstick straight up to remove it from the controller.
  10. Amazon Luna Controller Shell Replacement, Shell: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Luna Controller Shell Replacement, Shell: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently grab the controller's circuitry and hold the bottom shell.
    • Pull the circuitry gently out from the shell.
Cade Queen
crwdns2935283:009/04/24crwdne2935283:0
537 crwdns2915208:0crwdne2915208:0
Western Carolina University, Team 1-4, Virtue Fall 2024 crwdns2935289:0Western Carolina University, Team 1-4, Virtue Fall 2024crwdne2935289:0
WCU-VIRTUE-F24S1G4
After putting it together, did your B button work again? I can't get mines to function anymore. The joysticks are also moving around a lot on their on.
SophisticatedCheese - crwdns2934203:0crwdne2934203:0
I would check your reassembly and make sure none of the pads are damaged under the buttons
Ethan Phillips - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 97
