Amazon Fire TV Cube Motherboard Replacement
  1. Amazon Fire TV Cube Motherboard Replacement, Speaker: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire TV Cube Motherboard Replacement, Speaker: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire TV Cube Motherboard Replacement, Speaker: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a metal spudger, push down between the edge seals on the base and pry off the base.
    • Do not confuse the top thin layer of rubber with the thick palette that needs to be removed.
    • This may require substantial force.
  2. Amazon Fire TV Cube Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire TV Cube Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire TV Cube Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
    • There are 4 washers to go with each of the screws.
  3. Amazon Fire TV Cube Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift and remove the full frame.
  4. Amazon Fire TV Cube Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire TV Cube Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the speaker.
    • Carefully match the outlets on the speaker with the outlets on the motherboard.
  5. Amazon Fire TV Cube Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire TV Cube Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the black latch by gently prying up with the flat end of the Spudger.
    • Detach the copper tap by pulling it out.
  6. Amazon Fire TV Cube Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire TV Cube Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard.
    • Make sure all three attachments (the copper tab and both wires) are fully disconnected before continuing.
  7. Amazon Fire TV Cube Motherboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire TV Cube Motherboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pry the motherboard up and off.
    Nobody anywhere has these motherboards so what good are instructions to replace. It’s like being given a car that doesn’t have keys and those keys can’t be made anywhere.
    futuregu - crwdns2934203:0crwdne2934203:0
Piper Kaul
crwdns2935283:009/27/18crwdne2935283:0
235 crwdns2915208:0crwdne2915208:0
Linn Benton Community College, Team S1-G1, Johnson Fall 2018 crwdns2935289:0Linn Benton Community College, Team S1-G1, Johnson Fall 2018crwdne2935289:0
LBCC-JOHNSON-F18S1G1
where do you buy the mother board ?
Sam Handa - crwdns2934203:0crwdne2934203:0
This would be perfect if I could buy the dam motherboard. Where does one get because so far I’m not finding crap.
crwdns2942667:0crwdne2942667:0 1,911
