These steps will guide you through the disassembly and the replacement of the Fire TV Cube motherboard. This guide requires the metal flathead spudger. Use extra caution when detaching wires.
Using a metal spudger, push down between the edge seals on the base and pry off the base.
Use the T-10 bit from the iFixit tool kit to unscrew the four 1.4 inch corner screws on top of the first layer.
Lift the black latch by gently prying up with the flat end of the Spudger.
Detach the copper tap by pulling it out.
Use the pointed end of the Spudger to carefully detach the black and white wires from the motherboard.
Gently pry the motherboard up and off.
where do you buy the mother board ?
This would be perfect if I could buy the dam motherboard. Where does one get because so far I’m not finding crap.
