Amazon Fire Phone Battery Replacement
Lissandra Ilcyn
crwdns2944107:0crwdnd2944107:0Lissandra Ilcyncrwdnd2944107:0crwdnd2944107:0crwdnd2944107:08crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Ndz 24, 2023crwdne2944111:0
crwdns2931287:030crwdne2931287:0 - crwdns2931289:01crwdne2931289:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
Use this guide to replace the battery in your Amazon Fire Phone.
crwdns2944105:0crwdne2944105:0
  1. Amazon Fire Phone Battery Replacement, Tape the screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If the display is damaged, use clear packing tape to contain any glass shards.
    • Make sure the entire surface of the display is covered with tape.
    • Wear safety glasses to protect your eyes.
  2. Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Battery Replacement, Power off, remove SIM card, remove screws: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off your phone.
    • Remove the SIM card from the left side of the phone by pressing the small hole and allowing it to eject using the 0.8 screwdriver head.
    • Remove the two 4mm screws on the bottom of the phone using the Torx T3 screwdriver.
  3. Amazon Fire Phone Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Fire Phone Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Press the small suction cup just above the home button.
    • While lifting up on the suction cup insert an opening pick into the crevice between the screen and back casing to pry the screen off carefully.
    • Carefully separate the two halves to avoid tearing the volume rocker ribbon cable.
    • Using the opening tool, disconnect the volume rocker ribbon cable from the base of the phone freeing the two halves of the phone.
  4. Amazon Fire Phone Battery Replacement, Remove Bracket: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the J000 screwdriver head, remove the three 3mm screws holding the bracket in place.
    • Remove the silver bracket that was held into place by the three screws just removed.
    I kind of like the way the battery just “disappears” between step 5 and 6; mine was glued in with a REALLY good quality adhesive tape that took some chiseling to get free; happily, the battery didn’t explode, hopefully it will still work.
    vincentfasano - crwdns2934203:0crwdne2934203:0
  5. Amazon Fire Phone Battery Replacement, Disconnect Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery connection cable by using the plastic opening tool and applying light pressure upwards on the cable.
    Single hardest step, removing this battery takes both time and the jaws of life, it has an adhesive strip that will nearly RIP the battery or motherboard of the phone part, just keep careful while your at it, both mine and my wifes survived the tearing of this battery out, iv never been so sure I was breaking something while removing the battery but they went back together very easily once the devil adhesive let the battery go. This battery the the differential between a 1star difficulty and the 5star difficulty.
    Isaaru Narom - crwdns2934203:0crwdne2934203:0
    I didn’t know Amazon made a phone it looks like iPhone when you opened it nice guide man
    Maxem - crwdns2934203:0crwdne2934203:0
crwdns2935229:022crwdne2935229:0
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0
Lissandra Ilcyn
crwdns2935283:010/05/15crwdne2935283:0
862 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 5-7, Maness Fall 2015 crwdns2935289:0Cal Poly, Team 5-7, Maness Fall 2015crwdne2935289:0
CPSU-MANESS-F15S5G7
crwdns2947412:014crwdne2947412:0
The replacement went exactly as presented. My stock battery had pull tabs to release the adhesive, making removal very easy. Thanks for a clear step-by-step guide.
John - crwdns2934203:0crwdne2934203:0
How to bay amazone fire fone battry in pakistan
Manzoor Khan - crwdns2934203:0crwdne2934203:0
where can i get fire phone battery in india
Shiva Sai - crwdns2934203:0crwdne2934203:0
where can i get fire phone battery in UAE Abu Dhabi. It's urgent..
Asheesh Barna - crwdns2934203:0crwdne2934203:0
IS IT POSSIBLE TO GET Amazon Fire Phone, 32GB 4G LTE, Battery ?
Zaheer - crwdns2934203:0crwdne2934203:0
here in UAE i want battery fo my Amazon Fire Phone, 32GB 4G LTE,
These instructions were extremely helpful - even essential. One additional item: it would have been reassuring to caution that the original battery is (or at least was, on my model) tightly bound by adhesive lining the whole underside of the battery. I was very nervous getting the battery out. Removing it required working a thin screwdriver underneath the long lip of the battery, and working it back and forth to stretch and cut the adhesive free. When putting the new battery in its place, I made some two-sided sticky loops from packing tape to hold the new battery in place, in case it might have a tedency to shift around and rattle slightly.
gjyaffe - crwdns2934203:0crwdne2934203:0
thx for these instructions. my firephone 64mb was rebooting again and again with white amazon logo. thougt my data was lost forever. tried this here with akku changing and voila …
but the part with getting off the - taped - akku itself out of the case was very difficult using a screwdriver and a knife. also causing a electrical short (smoke appearing)
within the akku.
FPhoneuser - crwdns2934203:0crwdne2934203:0
Big problem - disconnect the battery lead, and you are Not at Conclusion.
The battery is so tightly secured with adhesive, there is no way to know that there are not other fasteners holding it in place.I
The battery literally must be destroyed to remove it.
That is a major and frustrating omission.
Brian Carter - crwdns2934203:0crwdne2934203:0
when i try to charge my cell its blink charging icon again and again but the end of the day it was not charged
Tanzeel arts - crwdns2934203:0crwdne2934203:0
I lost my fire phone's silver bracket , please any expert tell me is there any problem occurred if I assemble phone without it??
Discover With Me - crwdns2934203:0crwdne2934203:0
Where can i get the battery in zambia
Mandala Hankalu - crwdns2934203:0crwdne2934203:0
i want to replace the battery in amazon fire phone
moesat yinkhwin - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 53
crwdns2942667:0crwdne2942667:0 13,413
