A micro SD card is important when storing information on your device. This guide will explain how to install a micro SD card into your Amazon Fire Max 11 or replace an existing one if it is faulty or slow.
Press a SIM card tray pin (or a paper clip if you do not have the pin) into the hole in the side of the SIM card tray to eject the tray.
Remove the existing SIM card from the device.
Close the SIM card tray.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
