Amazon Fire Max 11 Battery Replacement
    1. Amazon Fire Max 11 Battery Replacement, LCD Touch Screen: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • The heat gun can get very hot and can burn skin. If the device is heated for too long, it can be damaged.
      • Use a heat gun along the edges of the screen to loosen the adhesive.
      • Insert the iFixit opening tool along the seam between the screen and back case and gently pry around the perimeter of the screen.
    2. Amazon Fire Max 11 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire Max 11 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Once the screen has been separated from the case, lift it slightly to reveal the display cable connected to the motherboard.
      • Gently push the tip of a spudger under the metal buckle to unclip it, then swing it over the socket.
      • Next, hold the buckle and cable together and gently pull the connector straight out of its socket.
      • To reconnect:
      • Grip the cable and buckle together and insert the connector fully into its socket.
      • Aligning the connector can be tricky. Reposition it as necessary and don't try to force it into the socket, or you may damage both the connector and its socket.
      • Flip the buckle over the socket and use a spudger to press the buckle down until it clicks into place.
      • Remove the screen.
    1. Amazon Fire Max 11 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift up the black flaps protecting the battery from the screen.
      • They have an adhesive surface but can be removed easily.
      • Set them aside as you will put them back once you replace the battery.
    2. Amazon Fire Max 11 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire Max 11 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #000 screwdriver to remove the two screws securing the bracket that connects the motherboard to the magnetic connection port for keyboards through a long, slim wire.
      • Remove the bracket.
    3. Amazon Fire Max 11 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Place a spudger or an opening tool under the press connector's edge and pry straight up to disconnect it.
      • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
      • Work carefully: don't pry on or accidentally scrape any small, surface mounted components on the board.
      • To reconnect, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      • Don't press down on the middle of wider connectors until they're fully seated. If misaligned, the connector or the pins underneath can bend or break, causing permanent damage.
    4. Amazon Fire Max 11 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire Max 11 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Use a Phillips #000 screwdriver to remove the single screw securing the black bracket above the right corner of the battery.
      • Lift the wire up and unplug the connector.
    5. Amazon Fire Max 11 Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Fire Max 11 Battery Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently disconnect the battery cable from the socket on the motherboard.
      • Use a Jimmy to pry the battery from the device starting from the bottom of the battery towards the keyboard connection port.
      • Remove the battery.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Anthony Martins
crwdns2935283:003/18/24crwdne2935283:0
522 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 1-3, Konn Spring 2024 crwdns2935289:0UMass Dartmouth, Team 1-3, Konn Spring 2024crwdne2935289:0
UMASSD-KONN-S24S1G3
crwdns2935297:048crwdne2935297:0
crwdns2936753:07crwdne2936753:0 22
crwdns2936753:030crwdne2936753:0 84
crwdns2942667:0crwdne2942667:0 1,845
