You will need to use the screen replacement guide as a prerequisite.
Use a plastic opening tool to pry the screen up in the right hand corner.
Lift the screen and digitizer from the case.
What is a ZIP connector? What does it look like?
Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
Disconnect the ribbon connector from the digitizer side using your hands or the plastic opening tool.
Remove the screen and digitizer from the case completely.
Remove the two screws from front facing camera using the T5 Torx Screwdriver.
Lift the black plastic cover once the screws are removed.
Place aside for later reassembly.
Detach the connector using a plastic opening tool or spudger.
Grip the camera and lift up to detach the ZIF connector from the motherboard.
Can this camera module be upgraded with a better version?
The right side with the power switch on top?
Sonny Shear - crwdns2934203:0crwdne2934203:0
Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
Thanks!
Steve Ciciora - crwdns2934203:0crwdne2934203:0
What if there are no pull tabs? It is stuck down on both sides in a metal tray. This is an hd 10 plus 11th generation.
Traci R - crwdns2934203:0crwdne2934203:0
