Amazon Echo Studio Power Supply Board Replacement
Nick Saranich
crwdns2944107:0crwdnd2944107:0Nick Saranichcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mha 17, 2023crwdne2944111:0
10 - 15 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2942287:0crwdne2942287:0
If your Amazon Echo Studio does not power on, and you have tried a new power cord and have confirmed that the issue is not from the outlets you are plugging it into, you might need to replace the power supply. This guide will tell you how to open up the Amazon Echo Studio and replace the power supply board.
crwdns2944105:0crwdne2944105:0
  1. Amazon Echo Studio Power Supply Board Replacement, Power Supply Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Power Supply Board Replacement, Power Supply Board: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Power Supply Board Replacement, Power Supply Board: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the device upside down.
    • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
  2. Amazon Echo Studio Power Supply Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Power Supply Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Power Supply Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
    • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
    • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
    As the diagram shows, there are actually nine T15 Torx screws, not ten.
    Brian Dipert - crwdns2934203:0crwdne2934203:0
    Good catch, Brian.
    Connor -
  3. Amazon Echo Studio Power Supply Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Power Supply Board Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Studio Power Supply Board Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before fully removing the base, remove the three attached connectors.
  4. Amazon Echo Studio Power Supply Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Studio Power Supply Board Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now unscrew the the single 10 mm Phillips screw.
    • Remove the power supply board.
    I hope this helps some folks.
    My echo studio blows the fuse in the plug every time I plug it in.
    I believe the culprit is a high voltage ceramic capacitor located under the foam insulation next to a large transistor and a large green resistor next to the heat sync. See images below.
    https://ibb.co/R7jbvDQ
    https://ibb.co/gFvchcG
    https://ibb.co/jTxXZvc
    https://ibb.co/d2fs15m
    https://ibb.co/sKTq3G7
    I have ordered a replacement capacitor so I'll let you know if this is in fact the problem or just a casualty of the problem.
    Horrox101 - crwdns2934203:0crwdne2934203:0
Nick Saranich
crwdns2935283:010/24/22crwdne2935283:0
297 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-6, Petersen Fall 2022 crwdns2935289:0UMass Dartmouth, Team 2-6, Petersen Fall 2022crwdne2935289:0
UMASSD-PETERSEN-F22S2G6
crwdns2947412:013crwdne2947412:0
Thank you for this guide. It was very easy operation, but I believe problem with Echo is that its impossible to get spare parts?
My Echo Studio is in short circuit state.
https://ibb.co/kqTXw0w
https://ibb.co/zV4KH6y
https://ibb.co/GMgPDDY
https://ibb.co/4PMZjDj
https://ibb.co/k0MsFPM
Kertalaaki - crwdns2934203:0crwdne2934203:0
Taking this thing apart really is easy. Thanks for the tip on how to get started. But as Kertalaaki figured, it seems there is no chance to get replacement parts. I guess Amazon prefers to sell new devices instead of having people repair their Studio device. I have a similar problem Kertalaaki describes. Whenever I plug the device in, it causes the breaker to blow. Now having the device in hand, I can't see any obvious damage as Kertalaakis photos show, but I still would like to get me a new power supply board. If anyone has any ideas on how to get one, please share! Thanks a lot in advance!
Ingo Gambin - crwdns2934203:0crwdne2934203:0
Same Problem like Ingo and Kertalaaki. Did anyone figure out how to get a new power supply?
Martin Dirr - crwdns2934203:0crwdne2934203:0
I contacted the Amazon regarding the matter, and spare parts are not available. The solution from their side was a credit towards a new device with a discount. Spare parts are not available.
The power source is custom built just for this implementation and there is nothing similar on the market as far I have found.
bonjour je rencontre le meme probleme avec mon Echo Studioet impossible de trouver la carte d'alimentation.
christian lof - crwdns2934203:0crwdne2934203:0
I have exactly the same problem. Blows the fuse everytime I plug it in.
Bought November 2022 and broke 12 months later, the morning after the warranty ran out.
Stupot - crwdns2934203:0crwdne2934203:0
i found a shorted MOS FET (20N65) , one burned big resistor on the top side and two exploded SMD resitors on the bottom side
Thomas - crwdns2934203:0crwdne2934203:0
You don't neet 30VDC power supply as original used it need only ca. 0.3A by 30VDC from the power supply. I replease the old one supply for a new one I suggest you use/buy EPS-45S-24 from MEAN WELL 24VDC on output is just fine and work properly
EPS-45S-24 MEAN WELL - Napájecí zdroj: spínaný
Tom - crwdns2934203:0crwdne2934203:0
Didn't know why my Echo Studio, which had been working fine for over a year, just suddenly wouldn't work at all. It sat in the garage, unplugged for over a month until I found this video today, while looking for a place to send it for repair. Disappointed that parts aren't even available, at all, I about gave up. Then when I went to check which "version" of Studio I had, I unplugged the other one to use that power cord. I'll be danged! It came on and worked fine. In fact better than the other on. That one will not "remember" the set volume the next time it's turned on; same as one of my Alexa's. So, I'm happy I don't have to spend $200 to get another one. Good work, there. Now if I can get my Sub to play the same song as the Alexa's, that's my next challenge.
Ronald Hartigan - crwdns2934203:0crwdne2934203:0
same deal here, blows the mains whenever the PSU is plugged in (even w/o any load attached)
peeled off some of that silicone goo and revealed a popped THT capacitor
you can check your cap easily from the bottom side...
Have the "PRIMARY" text upright
it sits just right of the central rubber foot (touching the Drain pin of the MosFET Thomas was mentioning) and moves north to R131
sharing the copper Trace with the same MosFETs Source pin)
if you find a short there you are most likely to be having that same cap blown.
That unfortunately means you have to desolder at least one of the large caps (the inner one) to be able to carefully remove that goo
and finally replace that cap... I can't tell what value cap will be needed my first guess is "100pf 1kV"
itsid - crwdns2934203:0crwdne2934203:0
Plugged, nothing happens except for getting hotter on top. No signs of burnings or exploded things in power supply unit witch, however, has been placed in the bottom.. Can't say i'm 100% sure because of the amount of glue/whatever on it. Think I should test the power unit first and then go ahead and tear dowm the hole thing to check the light board on top. So, how to test it? I don't know where to put power and where to put the tester/multimeter. It will not work again, I know; let's use theese 200 € to learn something. Thanks to everybody, except for amazon.
sureitwontwork - crwdns2934203:0crwdne2934203:0
If you have problem with power supply board you can make your own, but you have to put it outside like an adapter, it needs 30v DC at 2 amps, you can make easily by connecting 2 adaters of 12v each in series, total = 24v, it worked well forme.
rohit kumar - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 57
crwdns2942667:0crwdne2942667:0 1,716
