Amazon Echo Show 5 Speaker Replacement
  1. Amazon Echo Show 5 Speaker Replacement, Amazon Echo Show 5 Disassembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Show 5 Speaker Replacement, Amazon Echo Show 5 Disassembly: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Show 5 Speaker Replacement, Amazon Echo Show 5 Disassembly: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Power off and unplug the Amazon Echo Show 5. Failure to do so could result in injury or damage to the device.
    • Orient the Amazon Echo Show 5 so that the display is face down.
    • Use a spudger to remove the grey bottom cover.
    • During reassembly, adhesive needs to be applied to secure the bottom cover.
  2. Amazon Echo Show 5 Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Show 5 Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three screws with a T6 Torx screwdriver.
  3. Amazon Echo Show 5 Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Show 5 Speaker Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Show 5 Speaker Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to release the six internal tabs lining the sides of the device.
    • There are fragile ribbon connectors along the side of the screen with the camera on it. So, do not stick the spudger more than a couple millimeters into the device.
  4. Amazon Echo Show 5 Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully open the device by folding it open along the top edge where the camera is located.
    • Do not try to open the device from any other side as this would damage the ribbon connectors.
  5. Amazon Echo Show 5 Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Show 5 Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Show 5 Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully disconnect the red and black power connector.
  6. Amazon Echo Show 5 Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Show 5 Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Show 5 Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the three ZIF connector ribbon cables that connect the speaker housing to the display housing.
    • Do not pull ribbon cables straight out, as this will damage the device. To safely remove ribbon cables, pull up on the tab where the cable is going into.
  7. Amazon Echo Show 5 Speaker Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Show 5 Speaker Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Show 5 Speaker Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws securing the speaker using a T6 Torx screwdriver.
  8. Amazon Echo Show 5 Speaker Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Show 5 Speaker Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Show 5 Speaker Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull back the silver tape.
  9. Amazon Echo Show 5 Speaker Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully pull out the speaker housing from the black ledge.
David Degbor
crwdns2935283:010/26/22crwdne2935283:0
277 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 2-4, Petersen Fall 2022 crwdns2935289:0UMass Dartmouth, Team 2-4, Petersen Fall 2022crwdne2935289:0
UMASSD-PETERSEN-F22S2G4
crwdns2947412:05crwdne2947412:0
where can i locate a replacement loud speaker?
Mick Mul - crwdns2934203:0crwdne2934203:0
Ive taken my speaker out and tested it, its fine
Its a software or dac chip issue.
Chris Foure -
Agreed , my speaker is muffled , ive just disassembled and want to test the speaker .
And... Yes ive reset thr device etc many times.
Chris Foure - crwdns2934203:0crwdne2934203:0
I think I have the same muffled speaker issue. This unit has also had on-and-off problems with signal reception and understanding commands. I should have returned it to Amazon right off. I've been tempted to fix it with a sledgehammer.
deltapark - crwdns2934203:0crwdne2934203:0
I have the same issue with mine. Just cuts out when playing music. To day I just ran her usly I bt to the radio. The speaker sounds blown. Just crackels
Eric West -
crwdns2942667:0crwdne2942667:0 1,465
