Amazon Echo Power and Speaker Driver Board Replacement
  1. Amazon Echo Power and Speaker Driver Board Replacement, Power and Speaker Driver Board: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off and unplug your Echo before disassembly. Failure to do so could result in injury or damage to the device.
    • Peel off the rubber footing from the bottom of the Echo.
    • Do not pull the rubber footing too hard, as it could stretch out of shape. Use a spudger to help remove the foot if you have any trouble.
  2. Amazon Echo Power and Speaker Driver Board Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Power and Speaker Driver Board Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Power and Speaker Driver Board Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 42.8 mm T10 Torx screws from the bottom of the Echo.
  3. Amazon Echo Power and Speaker Driver Board Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly lift the plate containing the board. Be careful not to disconnect any of the wires.
  4. Amazon Echo Power and Speaker Driver Board Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, carefully disconnect the two red and black cables from their sockets on the board.
    • Tugging on the wires may damage the device. Pull from the plastic connectors instead.
    Könnt ihr Ersatzteil machen für Amazon Echo
    Okka Mehmed - crwdns2934203:0crwdne2934203:0
    Wo kann ich Ersatzteile holen für Amazon Echo
  5. Amazon Echo Power and Speaker Driver Board Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Power and Speaker Driver Board Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the brown plastic latch on the ZIF connector securing the driver board ribbon cable.
    • Pull the ribbon cable from its connector. The plate and board should now be free from the Echo.
  6. Amazon Echo Power and Speaker Driver Board Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Power and Speaker Driver Board Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Power and Speaker Driver Board Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using the spudger, pull back the two plastic clips on the plate.
    • Lift the board up and pull it away from the plate.
    I need to find a replacement board. Where can I find one?
    Matthew Webster - crwdns2934203:0crwdne2934203:0
    Me to, i need this board to my alexa echo
    benjaminaflorentino - crwdns2934203:0crwdne2934203:0
    So anyone found out where we can get these boards and other components ?
    Jimmy - crwdns2934203:0crwdne2934203:0
    I need this board to my echo 2nd, where can I find one?
    Pedro B - crwdns2934203:0crwdne2934203:0
crwdns2935229:010crwdne2935229:0
Alexander Albert
crwdns2935283:002/04/16crwdne2935283:0
1 169 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-3, Wollert Spring 2016 crwdns2935289:0USF Tampa, Team 3-3, Wollert Spring 2016crwdne2935289:0
USFT-WOLLERT-S16S3G3
crwdns2947412:022crwdne2947412:0
It's great that you have provided these instructions. I need to do this with mine. Do you know where I can get a replacement board?
Taylor Wolf - crwdns2934203:0crwdne2934203:0
Taylor, did you ever find a new board? I need one too.
Mark Hall -
Great instructions BUT ...... THERE IS NO PLACE TO BUY THE BOARD!! (It's proprietary to Amazon) So this instruction is about as useful as jumping out of a plane before asking for a parachute.
blueskymining -
Where do I get a replacement board ?
Sean Burch - crwdns2934203:0crwdne2934203:0
ya that's a thing need to fix it... where is it?
Matt Hurlburt - crwdns2934203:0crwdne2934203:0
Did anyone ever find a board?
Jim Eggleton - crwdns2934203:0crwdne2934203:0
I guess we were all left hanging with the board successfully de-attached.... Any news on were to find the new board?
Alejandro Castaño - crwdns2934203:0crwdne2934203:0
I also need a new board. I'm beginning to doubt that you can get these, unless you can cannibalize them from another Echo.
ericdthomson - crwdns2934203:0crwdne2934203:0
Duh. Where'd you get that clue .... like the 18 other comments that there ARE NO BOARDS available?
They need to change the name of this site from Fixit to SUCKER.com
blueskymining -
I also need to buy a new board but nobody knows where.... :-(
Sadilmar Goularte - crwdns2934203:0crwdne2934203:0
USELESS DISASSEMBLY instructions because the Author either is clueless, or knew all along YOU CAN'T BUY THESE BOARDS ANYWHERE!!
blueskymining - crwdns2934203:0crwdne2934203:0
I spilled coffee in the cup holder that the Echo was sitting. This knocked out its ability to speek. If you all can't find a replacment sound board you might try this. Everything seems to be working but she can't talk. I took my blue tooth speeker and pared to my mute Echo and it worked. It now has its voice back. I still would like to know if you can buy a replacement board. if anyone has information on getting one, post it please.
fin4080 - crwdns2934203:0crwdne2934203:0
Successfully fixed my Echo using this guide. Here is some of my insight that I gained during this fix:
1. Bought a broken Echo on Ebay for spare parts.
2. Don't break the ZIF connector, it's fragile. It flips up towards the ribbon cable.
3. I found that my Echo was not broken at all, (until I messed with it). I thought the power jack was broken in a fall because I couldn't plug the power cord back in. The power cord that came with my Ebay Echo inserted fine. I later broke the power jack while troubleshooting, everything in there is BRITTLE. Check to see if your plug is your problem too!
4. Everything in there is very brittle, use gentle hands.
imbranato - crwdns2934203:0crwdne2934203:0
One last thing, I couldn't find the threads for the long screws during reassembly. I did some further disassembly on my Ebay Echo to find why and here is what I found: The long screws thread into the tweeter which is located just below the power board. If you look at the "Tweater Assembly" teardown, step 9, you can see these four holes NOT circled in red. In my case, my echo was disassembled for a few weeks and the housing had shifted slightly making it difficult to find the holes. The fabric surrounding the speaker made it more difficult to line up holes too. I used a scribe to ensure that they were inline and then the screws went back together nicely. Good luck!
Has anyone found a board replacement?  I think our output board has a component which overheats and fails i.e. Alexa can’t talk but lighted ring rotates as though she is.  Not sure how to find the component which is problematic.
Michael Bethell - crwdns2934203:0crwdne2934203:0
Anyone find a replacement board?
If you all can't buy a board, why don't you go buy another Echo?
Arlene Knuth - crwdns2934203:0crwdne2934203:0
I have a dead echo and difficult to diagnose a fault. Can't see any burnt bits on the boards altho one tale-tale piece of damage to screw hole in the lid. Is there any point identifying a fault if there are no parts available? Presumably my best bet is another dead echo or a cheap used one? Anyone got a dead echo they don't want?!?
spezzer - crwdns2934203:0crwdne2934203:0
Parts can be found on eBay guys. If that doesn’t work for you then you can get 25% off another device if you trade in your broken one to Amazon.
Andrew K - crwdns2934203:0crwdne2934203:0
where can i get a replacement board
212Salon AndDaySpa - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 56
crwdns2942667:0crwdne2942667:0 27,797
