Amazon Echo Dot 3rd Generation Speaker Replacement
  1. Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Generation Speaker Replacement, Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Speaker Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Dot 3rd Generation Speaker Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Speaker Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Speaker Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Dot 3rd Generation Speaker Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
  5. Amazon Echo Dot 3rd Generation Speaker Replacement, Speaker: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four black 8.4 mm screws surrounding the speaker using a JIS #1 screwdriver.
  6. Amazon Echo Dot 3rd Generation Speaker Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Generation Speaker Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Generation Speaker Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to pry the speaker out of the device.
    Where do I find a new speaker?
    Matt Gallo - crwdns2934203:0crwdne2934203:0
Elaina Moore
crwdns2935283:009/15/22crwdne2935283:0
151 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 3-2, Lane Fall 2022 crwdns2935289:0University of Memphis, Team 3-2, Lane Fall 2022crwdne2935289:0
UM-LANE-F22S3G2
crwdns2947412:011crwdne2947412:0
Now where do I get the new speaker?
Philip Terry - crwdns2934203:0crwdne2934203:0
Now WHERE do I get the new speaker?
vinodhkumar chejarla - crwdns2934203:0crwdne2934203:0
WHERE DO WE GET THE REPLACEMENT speaker!?
Jerry Perry - crwdns2934203:0crwdne2934203:0
If you have a new one and the bass is a bit rattly just losten the speaker screws push lightly on the speaker whilst tightening the screws back up. It reduces the pressure and keeps the driver from hitting the case or moving to far out
GrantersG - crwdns2934203:0crwdne2934203:0
This is only if the speaker isn’t actually blown.
GrantersG -
Where do we get the new speaker mother fc ker
Fcukermother - crwdns2934203:0crwdne2934203:0
A link to a site selling replacement speakers, or a part number so we could search ourselves would have been helpful!
Neil Berry - crwdns2934203:0crwdne2934203:0
Amazon does not sell any parts for the Echo devices. The best and probably only alternative is to buy a used Echo at eBay and use this guide to replace the speaker.
raymondjram -
The speaker is most likely a 1.5"/1.6" 40mm full range speaker. So far I have been able to reglue the cone to stop the rattle. Souring the correct speaker may be tough, or cost prohibited. Used Gen 3 is about $10-15, even a Gen 4 on sale is about $30.
Frame size 1.6 inches 40MM, thickness 18MM, voice coil size 26.5MM, installation opening 1.5 inches 38MM, diagonal gong distance 45MM, M1.5
Most likely 4ohm 8watt.
Jeffery Cates - crwdns2934203:0crwdne2934203:0
you all are nasty as &&^&, get a life. Do a 2 second research on aliexpress.
Riccardo - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 15
crwdns2936753:07crwdne2936753:0 48
crwdns2936753:030crwdne2936753:0 216
crwdns2942667:0crwdne2942667:0 6,266
