Amazon Echo Dot 3rd Generation Motherboard Replacement
Jacquelyn Jones
crwdns2944107:0crwdnd2944107:0Jacquelyn Jonescrwdnd2944107:0crwdnd2944107:0crwdnd2944107:05crwdnd2944107:0crwdne2944107:0
crwdns2944111:0Mud 7, 2024crwdne2944111:0
5 - 15 crwdns2931279:0crwdne2931279:0
crwdns2937801:0crwdne2937801:0
crwdns2862637:0crwdne2862637:0
crwdns2942287:0crwdne2942287:0
If your Amazon Echo Dot 3rd Generation is experiencing hardware issues, but the app is still functioning, your motherboard may need to be replaced. Follow this guide to do so.
The motherboard, or main board, of the Echo Dot is the control center from which your device takes all its commands. If your main board is not functioning properly, it will need to be replaced.
Before replacing the main board, check your device for other causes of disruption. For example, if you find that Alexa is not responding to you, but the lights are functioning, you may be experiencing a speaker issue.
Before attempting, make sure the Echo Dot is turned off and unplugged from the external power source.
crwdns2944105:0crwdne2944105:0
  1. Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Generation Motherboard Replacement, Casing: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn the Echo Dot over so the barcode is facing up, giving you access to the bottom of the device.
  2. Amazon Echo Dot 3rd Generation Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Dot 3rd Generation Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a spudger to gently lift the adhesive covering between the casing and the device.
  3. Amazon Echo Dot 3rd Generation Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a T6 Torx screwdriver to remove the four 7.2 mm screws located around the corners of the device.
    • Make sure to keep the screws in a safe place for the reassembly process.
  4. Amazon Echo Dot 3rd Generation Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Amazon Echo Dot 3rd Generation Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently lift the casing of the device, starting from one side.
    • If the casing is stuck, use the spudger to carefully loosen it along the edges.
    • Be careful not to damage any internal components of the device.
  5. Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Generation Motherboard Replacement, Motherboard: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 6.2 mm screws from the motherboard using a T6 Torx screwdriver.
    • Remove the three 9.4 mm screws from the motherboard using a T6 Torx screwdriver.
  6. Amazon Echo Dot 3rd Generation Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Generation Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Amazon Echo Dot 3rd Generation Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the connecting head linking the motherboard to the device using a pair of tweezers.
    • Remove the old motherboard and replace it with the new one.
Jacquelyn Jones
crwdns2935283:009/15/22crwdne2935283:0
290 crwdns2915208:0crwdne2915208:0
University of Memphis, Team 3-2, Lane Fall 2022 crwdns2935289:0University of Memphis, Team 3-2, Lane Fall 2022crwdne2935289:0
UM-LANE-F22S3G2
Where do we get the parts you bi chh
Fcukermother - crwdns2934203:0crwdne2934203:0
Amazon does not sell any parts for the Echo devices. Your best and probably only alternative is to buy a used Echo from eBay and use this guide to repair it.
raymondjram -
Can you get or buy replament mother boards for the ehco 5 ?
Shawn Haywood - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 61
crwdns2942667:0crwdne2942667:0 2,137
