Use this guide to remove and replace the speaker in the Amazon Echo Dot 2nd Generation.
Power off and unplug the echo
Using the plastic opening tool, peel off the rubber layer on the bottom of the echo
Use the T8 screwdriver bit to unscrew the four 1.6mm torx screws
Remove the black, cylindrical base
Tap the base against the palm of your hand so that the black speaker component comes out
crwdns2935229:015crwdne2935229:0
Where can one purchase the replacement speaker component?
Can you inform us were to get replacement speaker please.
Yeah where can we buy the speaker? This tutorial doesn’t show how to replace it, it shows where to find it
