Alienware m15 R6 Display Replacement
  1. Alienware m15 R6 Display Replacement, Base Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws (M2.5x5) that secure the base cover to the palm-rest and keyboard assembly.
    • New line. Loosen the two captive screws (M2.5x8.5+3.5) that secure the base cover to the palm-rest and keyboard assembly
    • Loosen the four captive screws (M2.5x1.7+3.3) that secure the base cover to the palm-rest and keyboard assembly.
  2. Alienware m15 R6 Display Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your fingertips, pry open the base cover from the middle of the front edge of base cover, and then pry the left and right sides of the base cover.
    • Lift the base cover off the palm-rest and keyboard assembly.
  3. Alienware m15 R6 Display Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery cable from the system board.
    • Turn your computer over and press the power button for 20 seconds to drain the flea power
  4. Alienware m15 R6 Display Replacement, Rear-I/O cover: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two screws (M2x4) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
    • Remove the two screws (M2.5x5) that secure the rear I/O-cover to the palm-rest and keyboard assembly.
    • Disconnect the Tron light cable from the system board.
    • Firmly grasp the sides of your computer with both hands and push the rubber feet on the rear I/O-cover outwards with yourthumbs to release the rear I/O-cover from the palm-rest and keyboard assembly.
    • Slide the rear I/O-cover away from the palm-rest and keyboard assembly.
  5. Alienware m15 R6 Display Replacement, Display: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the latch and disconnect the display cable from the system board.
    • Disconnect the Alienhead LED cable from the system board.
    • Disconnect the RGB-IR camera cable from the USB board.
    • Lift the system board Mylar and peel the tapes that secure the RGB-IR camera cable to the system board.
    • Lift the RGB-IR camera cable off the system board.
    • Turn the computer over and place the computer on a clean and flat surface.
    • Remove the display cable from the routing guides on the palm-rest and keyboard assembly.
    • Remove the RGB-IR camera cable from the routing guides on the palm-rest and keyboard assembly.
  6. Alienware m15 R6 Display Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the six screws (M2.5x5) that secure the display hinges to the palm-rest and keyboard assembly.
    • Lift the display assembly off the palm-rest and keyboard assembly.
  7. Alienware m15 R6 Display Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • After performing all the above steps, you are left with the display assembly.
Andrzej
crwdns2935283:002/17/23crwdne2935283:0
1,672 crwdns2915208:0crwdne2915208:0
crwdns2935297:018crwdne2935297:0
How do you replace the LCD ribbon cable? It seems to be glued to the screen. I just need to replace that cable because it broke when I had to disconnect it to replace the charging port. :(
Melissa Ceyrolles - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 42
crwdns2942667:0crwdne2942667:0 967
