Alienware Pro Wireless Gaming Mouse Motherboard Replacement
  1. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Feet: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Feet: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Feet: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the mouse over so the bottom is facing up..
    • Use an opening pick to gently peel the mouse foot off the bottom case.
    • The mouse feet warp easily so if you're not replacing them, be careful and don't rip them off. You will need them when you reassemble the mouse.
  2. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel and remove the other mouse foot.
  3. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a TR6 Torx security screwdriver to remove the four 6 mm screws under the foot pads.
  4. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your hands or a spudger to separate the bottom and top of the mouse.
    • Insert the end of the spudger in the seam between the top and bottom case, and slide it around the perimeter to release the clips holding it together.
    • You may hear a cracking sound when the clips are released.
  5. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the pointed end of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket.
    • Avoid pulling on the wires. If necessary, pull as close to the connector as possible to prevent damage to your mouse.
  6. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • The battery is glued to the case.
    • Use an opening tool or spudger to loosen the adhesive under the battery.
    • Remove the battery.
  7. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Side Button: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Side Button: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pinch the upper part of the ribbon cable.
    • Pull the ribbon cable gently to detach it from the socket on the motherboard.
    • Make sure the ribbon line is facing the correct direction when reassembling the controller.
  8. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the side button panel from the plastic frame.
  9. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Scroll Wheel: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Scroll Wheel: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Scroll Wheel: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the scroll wheel encoder steady and gently pull the scroll wheel to the right to remove it.
    • Only light force is needed—be gentle to avoid damaging nearby parts.
  10. Alienware Pro Wireless Gaming Mouse Motherboard Replacement, Motherboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the two 5 mm screws at the bottom of the motherboard.
  11. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently pull the side clip away from the motherboard to release it from the plastic frame.
    • Use a spudger to release the board from the clips if that is easier.
  12. Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware Pro Wireless Gaming Mouse Motherboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Bend the front nose of the mouse body to release the motherboard.
    • Remove the motherboard from the bottom case.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Matt Seay
crwdns2935283:009/29/25crwdne2935283:0
401 crwdns2915208:0crwdne2915208:0
Austin Community College, Team 10-3, Watkins Fall 2025 crwdns2935289:0Austin Community College, Team 10-3, Watkins Fall 2025crwdne2935289:0
AUSTINCC-WATKINS-F25S10G3
crwdns2942667:0crwdne2942667:0 176
