Alienware AW610M Scroll Wheel Replacement
  1. Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware AW610M Scroll Wheel Replacement, Scroll Wheel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Turn your mouse over with the scroll wheel facing down.
    • Use a precision blade (I used size 12) to loosen the adhesive surrounding any stickers on the back of the mouse.
    • Be cautious with the blade and move in slow, controlled motions as to avoid any injury.
  2. Alienware AW610M Scroll Wheel Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware AW610M Scroll Wheel Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn your blowdryer on a low heat setting.
    • Precisely aim the heat on the adhesive sections of the mouse for 5-10 second intervals.
    • Turn off your blowdryer, unplug the device, and set it aside to cool down.
    • Carefully peel off the stickers, and set aside as well.
  3. Alienware AW610M Scroll Wheel Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware AW610M Scroll Wheel Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware AW610M Scroll Wheel Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use your Phillips #00 screwdriver to remove four 3.1 screws from the mouse.
  4. Alienware AW610M Scroll Wheel Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently prop open the back side of the mouse; be careful as to not break any plastic while doing so.
    • Don't pull apart the mouse backing too far, as connections still hold the two pieces together.
  5. Alienware AW610M Scroll Wheel Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware AW610M Scroll Wheel Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware AW610M Scroll Wheel Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect any wire connections away from the mouse's circuit board.
    • Be careful disconnecting the ribbon cable labeled AWM 20706, as you might not be able to reconnect it without damaging the pins, later on.
    • Locate the scroll wheel placed in the gap of the mouse's backing.
    • My scroll wheel was crooked, most likely causing my issue.
    • Gently lift the scroll wheel mechanism out of the mouse's backing.
  6. Alienware AW610M Scroll Wheel Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware AW610M Scroll Wheel Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware AW610M Scroll Wheel Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the scroll wheel sensor from the mouse backing.
    • Remove the old wheel from the plastic casing, and set it aside.
    • Use a dry cotton swab to wipe off dust or debris in the wheel's plastic casing.
  7. Alienware AW610M Scroll Wheel Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware AW610M Scroll Wheel Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware AW610M Scroll Wheel Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Dip a cotton swab into hydrogen-peroxide.
    • Make sure to wear gloves or wash your hands after handling hydrogen peroxide. Be cautious to avoid touching your face in this step.
    • Use a wet cotton swab to clean the mouse backing. Don't hesitate to swipe behind different pieces of plastic as well.
    • Avoid using cotton swabs on the circuit board of the mouse, or any wires in the mouse.
Rana Ashour
crwdns2935283:004/04/23crwdne2935283:0
193 crwdns2915208:0crwdne2915208:0
CSU Los Angeles, Team 2-71, Briggs Spring 2023 crwdns2935289:0CSU Los Angeles, Team 2-71, Briggs Spring 2023crwdne2935289:0
CSULA-BRIGGS-S23S2G71
Note: the tan part connected to the ribbon cable IS A RECEPTACLE, THE RIBBON CABLE ITSELF IS THE PART THAT PULLS OUT. I accidentally pulled off my connector, lost a connector pin when attempting to put it back on, mouse still seems to work though.
Nathan - crwdns2934203:0crwdne2934203:0
Hello, I followed all the steps but I'm left with the two springs that I don't know where to put. I didn't see the two springs in your pictures.
Morar Razvan - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 113
crwdns2936753:030crwdne2936753:0 486
crwdns2942667:0crwdne2942667:0 9,984
