Alienware 17 R4 Wi-Fi Card Replacement
  1. Alienware 17 R4 Wi-Fi Card Replacement, Base Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Wi-Fi Card Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
    pulled the battery cable let it sit for ten minutes and my no post problem was fixed
    thanks
    paul mohney - crwdns2934203:0crwdne2934203:0
  3. Alienware 17 R4 Wi-Fi Card Replacement, Wi-Fi card: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the WI-FI card.
  4. Alienware 17 R4 Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Wi-Fi Card Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Peel back plastic cover of wi-fi card.
    • Use a PH1 screwdriver bit and remove the one M2x3 screw (1.9 mm)
  5. Alienware 17 R4 Wi-Fi Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Wi-Fi Card Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Wi-Fi Card Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently undo the clips attached to the wi-fi card.
    • If the clip is not gently removed it is possible that the entire base will be torn off the wi-fi card. You will need to purchase a new wi-fi card if this occurs.
  6. Alienware 17 R4 Wi-Fi Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Wi-Fi Card Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Locate the cables that connect the wi-fi card.
    • Gently pull upwards to remove cables and slide the wi-fi card out from its slot.
    You don’t need to disconnect the WiFi card pins. I recommend leaving the antenna connections and just be careful when removing the frame in the next steps. The antenna connections are very fragile
    Colt Sammons - crwdns2934203:0crwdne2934203:0
    I second that... Came off OK... Gently... I just can't seem to get them reconnected on renistall. Ridiculously difficult...
    Louie Candreva Jr -
    This step should be removed. It is completely unnecessary to entirely disconnect the Wi-Fi card. There are no clearance issues that would necessitate this - the inner case can easily be removed around it.
    Luke - crwdns2934203:0crwdne2934203:0
    I agree, I did not disconnect the antenna cables after removing the WiFi card.
    David Johnson - crwdns2934203:0crwdne2934203:0
Hector Mendez III
crwdns2935283:009/11/17crwdne2935283:0
1,352 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team S2-G4, Bruce Fall 2017 crwdns2935289:0CSU Fullerton, Team S2-G4, Bruce Fall 2017crwdne2935289:0
CSUF-BRUCE-F17S2G4
What is the logic for removing the HHD prior to removing the WIFI card?
Roderick Vanderzalm - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 5,202
