Alienware 17 R4 Solid State Drive (SSD) Replacement
  1. Alienware 17 R4 Solid State Drive (SSD) Replacement, Base Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a PH1 screwdriver bit to remove the six M2.5x13 screws (2.4 mm) on the back of the laptop.
    • Use a PH1 screwdriver bit to loosen the one M2x3 screw (1.9 mm).
    • The M2x3 screw (1.9 mm) does not come out completely.
  2. Alienware 17 R4 Solid State Drive (SSD) Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Solid State Drive (SSD) Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the base cover up to remove it.
    • If you are having trouble, insert a plastic opening tool into the divots along the laptop's edges to loosen.
    • Removing the cover may require some force.
    pulled the battery cable let it sit for ten minutes and my no post problem was fixed
    thanks
    paul mohney - crwdns2934203:0crwdne2934203:0
  3. Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Solid State Drive (SSD) Replacement, Hard Disk Drive (HDD): crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the battery connector cable, located on the right side of the laptop, above the hard disk drive.
    • Once you have removed the cable, wait 5-10 minutes to allow the laptop to power down.
    • Failure to remove the battery connector cable properly may damage other parts of the laptop.
  4. Alienware 17 R4 Solid State Drive (SSD) Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Solid State Drive (SSD) Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Solid State Drive (SSD) Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a PH1 screwdriver bit to remove the four M2.5x5 screws (2.4 mm) on the hard disk drive.
  5. Alienware 17 R4 Solid State Drive (SSD) Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Solid State Drive (SSD) Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Alienware 17 R4 Solid State Drive (SSD) Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the HDD cable to disconnect it from the laptop.
  6. Alienware 17 R4 Solid State Drive (SSD) Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Solid State Drive (SSD) Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the hard drive up to remove.
  7. Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Solid State Drive (SSD) Replacement, Solid State Drive: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the one M2x3 screw (1.9 mm) using a PH1 screwdriver bit
  8. Alienware 17 R4 Solid State Drive (SSD) Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Alienware 17 R4 Solid State Drive (SSD) Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the solid state drive towards yourself to prevent damage to the card.
    How do I copy the contents of the old SSD to a new SSD. For example if I’m booting from my old SSD but want to update to a larger SSD.
    Shouldn’t step 1 be preserving my data? I give you a low score for lack of forethought. Guess another website might have pertinent information.
    Bill From Here - crwdns2934203:0crwdne2934203:0
Hector Mendez III
crwdns2935283:009/11/17crwdne2935283:0
1,352 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team S2-G4, Bruce Fall 2017 crwdns2935289:0CSU Fullerton, Team S2-G4, Bruce Fall 2017crwdne2935289:0
CSUF-BRUCE-F17S2G4
Is it advised to pull the HDD before pulling the SSD or is this guide just written in a way to cover how to remove both of them?
John Crooks - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 7,160
