Alienware 17 R2 Keyboard Replacement
    1. crwdns2952109:0crwdne2952109:0
    2. Alienware 17 R2 Keyboard Replacement, Close the Display: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Close the display and turn the computer over.
      • Make sure PC is turned off!
    3. Alienware 17 R2 Keyboard Replacement, Loosen Screws: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Loosen the captive screws that secure the base panel to the computer base.
    4. Alienware 17 R2 Keyboard Replacement, Releasing Tabs: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
    5. Alienware 17 R2 Keyboard Replacement, Remove Base Panel: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide and remove the base panel from the computer base.
    6. Alienware 17 R2 Keyboard Replacement, Disconnect Battery Cable: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Disconnect the Battery cable from the system board.
      • Turn the computer over.
      • Press and hold power button for 5 seconds to ground the system board.
    7. Alienware 17 R2 Keyboard Replacement, Battery Cable: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Connect the battery cable to the system board.
    8. Alienware 17 R2 Keyboard Replacement, Tighten Screws: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Tighten the captive screws that secure the base panel to the computer base.
      • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
      • Make sure the base panel is removed.
      • Make sure palm rest is removed.
      • Lift the latches and disconnect the touch-pad cable and the status-light cable from the power-button board.
    1. Alienware 17 R2 Keyboard Replacement, Peel off the Cables: crwdns2935265:012crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Note the touch-pad cable and status-light cable routing and peel off the cables from the keyboard bracket.
    2. Alienware 17 R2 Keyboard Replacement, Screw Removal: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screws that secure the keyboard bracket to the palm-rest assembly.
      • Slide the keyboard cable, keyboard-backlight cable, macro-keys cable and macro-keys backlight cable through the slot on the keyboard bracket.
    3. Alienware 17 R2 Keyboard Replacement, Lifting the Keyboard Bracket: crwdns2935265:015crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Lift the keyboard bracket off the palm-rest assembly.
    4. Alienware 17 R2 Keyboard Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Remove the screws that secure the keyboard to the palm rest assembly.
    5. Alienware 17 R2 Keyboard Replacement, Releasing the Tabs: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Release the tabs that secure the keyboard to the palm-rest assembly.
    6. Alienware 17 R2 Keyboard Replacement, Lifting the Keyboard: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slide and lift the keyboard along with the cables off the palm-rest assembly.
      • Slide the new keyboard under the tabs on the palm-rest assembly.
    7. Alienware 17 R2 Keyboard Replacement, Screw Alignment: crwdns2935265:020crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Align the screw holes on the keyboard with the screw holes on the palm-rest assembly.
      • Replace the screws that secure the keyboard to the palm-rest assembly.
      • Route the keyboard cable, keyboard-backlight cable, marco-keys cable and marco-keys backlight cable through the slots on the keyboard bracket.
      • Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
    8. Alienware 17 R2 Keyboard Replacement, Replace the Screws: crwdns2935265:024crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Replace the screws that secure the keyboard bracket to the palm-rest assembly.
      • Adhere the touch-pad cable and status-light cable to the keyboard bracket.
      • Slide the touch-pad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
Terrence15
crwdns2935283:012/18/17crwdne2935283:0
80,137 crwdns2915208:0crwdne2915208:0
crwdns2935297:0441crwdne2935297:0
RampUP America, Inc. crwdns2935289:0RampUP America, Inc.crwdne2935289:0
Community
crwdns2931471:045crwdne2931471:0
crwdns2935297:012,277crwdne2935297:0
I find it concerning that this guide has you disconnect and reconnect the battery prior to doing anything with the keyboard.
Sean Hanson - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
crwdns2936753:07crwdne2936753:0 38
crwdns2936753:030crwdne2936753:0 120
crwdns2942667:0crwdne2942667:0 3,039
