In this guide, we will be showing you how to remove and replace the Base Panel.
Close the display and turn the computer over.
Loosen the captive screws that secure the base panel to the computer base.
Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
Slide and remove the base panel from the computer base.
Disconnect the Battery cable from the system board.
Press and hold power button for 5 seconds to ground the system board.
Connect the battery cable to the system board.
Tighten the captive screws that secure the base panel to the computer base.
