Alan 48 Excel: Reception problems? No problem!
      • First of all: Power off! Switch it off and unplug the device.
      • Then grab your screwdriver and undo the screws on the housing.
      • Carefully lift off the housing and put it to one side.
      • Check all cables and connections. Are they properly seated?
      • Especially important: Check the connections to the antenna and the loudspeaker.
      • Time for some contact spray and brushes! Spray the connections thoroughly.
      • Wait a few minutes, then wipe away the residue with a clean cloth.
    1. Alan 48 Excel: Reception problems? No problem!, Check the transistor “Q104 (KTK 161)”: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Find the transistor “Q104 (KTK 161)” on the circuit board. Here it is:
      • Take your multimeter and check the transistor. If it is defective, it must be replaced.
    2. Alan 48 Excel: Reception problems? No problem!, Replace transistor “Q104 (KTK 161)”: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • In order to replace the transistor, carefully desolder the connections. This is where you need to start:
      • Insert the new transistor and solder it in place.
      • Check the connections with the multimeter to make sure that everything is properly working.
      • Put the housing back on and tighten the screws.
      • Plug in the plug, switch on the device.
      • Test whether the reception is now better.
That's it! With these steps, your Alan 48 Excel should have top reception again. If not, a major repair may be necessary.
crwdns2934873:0crwdne2934873:0
de en
100%
crwdns2934885:0crwdne2934885:0 crwdns2934875:0crwdne2934875:0
crwdns2958738:0crwdne2958738:0 ›
Ingo Bünnemeyer
crwdns2935283:006/06/16crwdne2935283:0
248 crwdns2915208:0crwdne2915208:0
crwdns2936753:030crwdne2936753:0 106
crwdns2942667:0crwdne2942667:0 2,115
