AirTag Battery Replacement
Kyle Smith
crwdns2944107:0crwdnd2944107:0Kyle Smithcrwdnd2944107:0crwdnd2944107:0crwdnd2944107:02crwdnd2944107:0crwdne2944107:0
crwdns2944111:0November 21, 2024crwdne2944111:0
1 - 2 crwdns2931279:0crwdne2931279:0
crwdns2937799:0crwdne2937799:0
crwdns2862627:0crwdne2862627:0
crwdns2942287:0crwdne2942287:0
Follow this guide to replace the battery in your Apple AirTag.
AirTags use one CR2032 coin cell battery.
  1. AirTag Battery Replacement, Push down the battery compartment door: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AirTag Battery Replacement, Push down the battery compartment door: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use both of your thumbs to push down on the battery compartment door.
    Die Daumen rutschen gerne ab, man denkt der Deckel klemmt. Abhilfe: z.B. Latex-Einmalhandschuhe (z.B. aus der Apotheke) anziehen, dann geht es ganz leicht, weil nichts mehr rutscht.
    Nano Mymse - crwdns2934203:0crwdne2934203:0
  2. AirTag Battery Replacement, Rotate the battery compartment door: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AirTag Battery Replacement, Rotate the battery compartment door: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Rotate the battery compartment door counter-clockwise to unlatch it from the frame.
  3. AirTag Battery Replacement, Remove the battery compartment door: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AirTag Battery Replacement, Remove the battery compartment door: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift up the battery compartment door to remove it.
  4. AirTag Battery Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 AirTag Battery Replacement, Remove the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift and remove the battery.
    • When you replace the battery, insert it such that the positive end is facing up.
    Das sollte man aus der Hersteller-Anleitung auch beachten: „CR2032-Batterien mit einer Bitterstoffbeschichtung funktionieren möglicherweise nicht mit dem AirTag oder anderen batteriebetriebenen Produkten, je nach Ausrichtung der Beschichtung in Bezug auf die Batteriekontakte.“
    Ob es funktioniert oder nicht, kann man so feststellen: Beim Hereindrücken der Batterie muß ein Piepston ertönen. Piepst es nicht, könnte es an der Bitterstoffbeschichtung liegen.
    Und bevor man nun lange herumsucht, sei diese überaus hilfreiche Erläuterung aus der iPhone-Gemeinde wiedergegeben:
    https://communities.apple.com/de/thread/... - Originalzitat:
    petereu
    04. Dez. 2022 18:54 als Antwort auf PreCognition
    Die CR2032-Knopfzellen von Panasonic funktionieren einwandfrei :-) Soweit ich sehe, verkauft nur Duracell die CR2032 mit Bitrex-Beschichtung. Man erkennt den Unterschied an der Aufschrift baby secure pack (keine Beschichtung) gegenüber baby secure pack & battery (mit Beschichtung).
crwdns2935229:022crwdne2935229:0
Kyle Smith
crwdns2935283:002/01/21crwdne2935283:0
45.562 crwdns2915208:0crwdne2915208:0
crwdns2935297:0123crwdne2935297:0
Bjr. Plus d’un an après l’achat de l’AirTag, impossible de l’ouvrir. Quand je presse avec 2 doigts, il ne se passe rien (le couvercle ne s’enfonce pas). Et le couvercle a l’air bloqué (grippé). J’hésite à utiliser une pince pour le tourner. Mon AirTag est resté depuis son achat dans une poche étanche de mon sac à dos. Il ne sonne plus quand je déplace ce dernier mais sonne si je le localise. Cdlt.
Eugénie Grandet - crwdns2934203:0crwdne2934203:0
Eugénie, excusez mon français. Essayez de saisir l'AirTag des deux côtés avec quelque chose qui a de l'adhérence, comme du silicone. Appuyez ensuite vers le bas et tournez. Assurez-vous de tourner dans le bon sens. Bonne chance!
Carsten Frauenheim -
Well done! One thing to add is that the replacement battery must not have a bitterant coating as they are problematic with the AirTags.
petermg - crwdns2934203:0crwdne2934203:0
Removing the bitterant with some isopropyl (rubbing) alcohol works if you aren’t able to find unflavored batteries near by.
Collin Reisdorf -
after the change of battery does the AirTag work as before automatically or does it need to be re-associated with the iPhone?
BaijuDC - crwdns2934203:0crwdne2934203:0
It should work automatically.
crwdns2936751:024crwdne2936751:0 51
crwdns2936753:07crwdne2936753:0 307
crwdns2936753:030crwdne2936753:0 1,386
crwdns2942667:0crwdne2942667:0 58,501
