Air Conditioning Thermostat Replacement
  1. Air Conditioning Thermostat Replacement, Turn Off the Power: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Air Conditioning Thermostat Replacement, Turn Off the Power: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Air Conditioning Thermostat Replacement, Turn Off the Power: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Before you begin, locate the circuit breaker switchboard for the housing unit.
    • Find the air conditioning breaker that’s typically labeled inside the breaker's panel cover.
    • Turn off the electrical breaker switch that supplies the air conditioning thermostat.
  2. Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Air Conditioning Thermostat Replacement, Remove the Existing Thermostat: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the thermostat casing off of the wall plate. It should come off easily using your hands, but a pair of pliers can be used if it's being stubborn.
    • Take a picture using your phone's camera of the color-coded wiring, so it will be easier to re-attach the wiring to the new thermostat.
  3. Air Conditioning Thermostat Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Air Conditioning Thermostat Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Air Conditioning Thermostat Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the Flathead 3/32" 2.5 mm Screwdriver to separate the color coded wiring.
    • Use the Phillips or flathead screwdriver to separate and un-wrap each of the color coded wires. (For example: notice the yellow wire)
    • Use the Phillips or flathead screwdriver depending on the type of model, to remove the Phillips #0 Plus screw, in order to remove the base plate.
  4. Air Conditioning Thermostat Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Air Conditioning Thermostat Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Air Conditioning Thermostat Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the old base plate of the thermostat.
    • Screw in the new base plate of the Thermostat using the Phillips or flathead screwdriver to screw in the Phillips #0 Plus screw drive.
    • Using the screwdriver; reconnect the color-coded wring based on the photo taken with your camera. (For example: Notice the yellow wiring)
  5. Air Conditioning Thermostat Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Air Conditioning Thermostat Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use your fingers to wrap the copper around the terminal slots, Use your Flathead 3/32" 2.5 mm Screwdriver to tighten the terminal slots. (For example: Notice the yellow wiring)
    • Fasten the terminal slots using your Phillips Flathead 3/32" 2.5 mm Screwdriver.
  6. Air Conditioning Thermostat Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Air Conditioning Thermostat Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the new thermostat casing over the base plate.
    • Snap on the thermostat casing.
  7. Air Conditioning Thermostat Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Air Conditioning Thermostat Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Air Conditioning Thermostat Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Locate the circuit breaker switchboard for the housing unit.
    • Locate the air conditioning electrical breaker switch.
    • Turn on the electrical breaker switch that the air conditioning thermostat supplies.
Genesis
crwdns2935283:003/01/17crwdne2935283:0
163 crwdns2915208:0crwdne2915208:0
ما هو السبب خروج علامت E3 في اسبلت westtin
السبلت ٣ طن عمودي
Hassan Alkanan - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,081
