Adjusting the Weight of a Logitech G502 Hero
crwdns2942287:0crwdne2942287:0If you are experiencing a 'weightless' Logitech G502 Hero, and would like to increase weight of the mouse for better usage, use this guide to properly adjust the weight on your Logitech G502 Hero.
Before using this guide, insure all original packaging equipment is located. To add this weight, the original packaging will provide the mentioned weights.
If you are interested in removing any weights, you must follow the guide in reverse order, unplugging the mouse being the first step.
Unplug the mouse from your computer
Turn the mouse so that the bottom of the mouse is upright.
Use your fingers to lift the magnetic backplate away from the mouse.
Adjust the weights by putting in as many weights as you desire.
Snap the magnetic plate back in the mouse.
I feel that putting a piece on the top-left corner (where the cover olds place) and in the very bottom or second to last position gives the mouse a more balanced feel
