Acer Spin 5 N17W2 SSD Replacement
  1. Acer Spin 5 N17W2 SSD Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Spin 5 N17W2 SSD Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Be sure to power off and unplug your device before you begin your repair.
    • Remove the twelve screws on the back cover using the Phillips #1 screwdriver.
    Not sure how you removed the back cover with a Philips head. Those are Torx screws. I actually came here to see what size Torx bit I need. Guess I won't find it here.
    Brad F - crwdns2934203:0crwdne2934203:0
  2. Acer Spin 5 N17W2 SSD Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use an opening tool to pry the back cover open.
  3. Acer Spin 5 N17W2 SSD Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove two 4 mm screws at the two corners of the battery using the Phillips #1 screwdriver.
  4. Acer Spin 5 N17W2 SSD Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully remove the three tapes on the battery.
  5. Acer Spin 5 N17W2 SSD Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully slide the battery connector out of its motherboard socket.
  6. Acer Spin 5 N17W2 SSD Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the device.
  7. Acer Spin 5 N17W2 SSD Replacement, SSD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the SSD from the laptop.
    • At the time of guide creation, the device did not come equipped with the SSD.
    That's not the ram, that's the m.2 ssd slot. The ram is soldered to the motherboard. And you don't have to completely remove the battery to access the m.2.
    Crusnik Arucard - crwdns2934203:0crwdne2934203:0
    Thanks for your feedback! We updated the guide to an SSD replacement guide, rather than RAM.
    Kristen Gismondi -
Noah Ryan Collier
crwdns2935283:002/20/20crwdne2935283:0
73 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G18, Eggleston Spring 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G18, Eggleston Spring 2020crwdne2935289:0
CMCSC-EGGLESTON-S20S3G18
That's not the RAM, that's the m.2 SSD slot. The RAM on this laptop is soldered to the mainboard and cannot be replaced/repaired.
Stephen Feger - crwdns2934203:0crwdne2934203:0
Ok, so they changed this guide from a RAM change to an SSD change. Fine. One thing to point out is that the default m.2 drive for this laptop is a SATA based m.2, not a PCIe. Not sure if it can handle a PCIe m.2 drive.
Stephen Feger -
crwdns2942667:0crwdne2942667:0 2,219
