Acer One 10 S1003-114M Screen Hinge Replacement
  1. Acer One 10 S1003-114M Screen Hinge Replacement, Screen Hinge: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Open the screen.
  2. Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screen portion from the keyboard.
  3. Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn over the keyboard and use the plastic opening tool to remove the two adhesive backed rubber pads furthest from the hinge.
  4. Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the ten total screws from the back cover with a Phillips #1 screwdriver.
    • 8 screws 4.25mm in length with 4.00mm diameter heads.
    • 2 screws 6.00mm in length with 4.00mm diameter heads.
  5. Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to separate the front and back halves of the keyboard.
  6. Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift away the loosened back cover.
  7. Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a pair of tweezers to remove the electrical connector for the hinge. Pull gently while wiggling the connector back and forth.
    • Remove the adhesive tape holding the wire down.
  8. Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To free the hinge, remove the 4 mount screws with a Phillips #0 screwdriver.
  9. Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer One 10 S1003-114M Screen Hinge Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the disconnected hinge from the keyboard.
    hi, where can I buy the hinge. it’s not available in my area. pls help me :(
    anis norudin - crwdns2934203:0crwdne2934203:0
Justin Bawinkel
crwdns2935283:004/01/19crwdne2935283:0
327 crwdns2915208:0crwdne2915208:0
IUPUI, Team S2-G6, Harley Spring 2019 crwdns2935289:0IUPUI, Team S2-G6, Harley Spring 2019crwdne2935289:0
IUPUI-HARLEY-S19S2G6
Where can I buy the hinges of acer one 10 D16H1?
ladysam020889 - crwdns2934203:0crwdne2934203:0
Do you know where I can find hinges of acer one s1003?
Al Monslisa - crwdns2934203:0crwdne2934203:0
The hinge is so stiff it broke off the keyboard tabs. I need to loosen the hinge and replace the keyboard base, or hopefully just the positioning tabs (if they can be reglued).
PGI Cruiser - crwdns2934203:0crwdne2934203:0
Tutoriel bien expliqué, merci pour tout, vous m’avez bien aidé à changer la charnière moi-même.
Francis Meylemans - crwdns2934203:0crwdne2934203:0
Where can i buy new hinge for acer one s1003 , plss suggest me
Arvind - crwdns2934203:0crwdne2934203:0
If the hing is broken then it is related to screen problem like screen filkring or screen blank
Albert - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 64
crwdns2942667:0crwdne2942667:0 7,015
