Acer Nitro 5 AN515-53-52FA Battery Replacement
  1. Acer Nitro 5 AN515-53-52FA Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Before starting the replacement, make sure the laptop is turned off and unplugged.
    • Flip the laptop upside down so that the bottom is facing up.
  2. Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the Phillips #0 screwdriver to unscrew the sixteen 9 mm screws holding the back cover in place.
  3. Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the opening pick to work your way around the edges to remove the bottom case carefully.
    • Do not try to put too much force on the shell off as you may damage it.
    This fails to mention that you should remove the hard drive before taking the shell off.
    ​​​ - crwdns2934203:0crwdne2934203:0
  4. Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Phillips #0 screwdriver to unscrew the four 9 mm screws holding the battery in place.
    You don't need to remove the bottom ones off, just the two on the top.
  5. Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the battery's motherboard connector with your fingers.
  6. Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Nitro 5 AN515-53-52FA Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery up and out of the laptop.
Alfredo Prieto
crwdns2935283:009/01/22crwdne2935283:0
926 crwdns2915208:0crwdne2915208:0
Gateway, Team 1-3, Pee Fall 2022 crwdns2935289:0Gateway, Team 1-3, Pee Fall 2022crwdne2935289:0
GCC-PEE-F22S1G3
Do I have to use other material to put the bottom case back on or is it easy to do by hand?
SomeDude372 - crwdns2934203:0crwdne2934203:0
Can I use a Jimmy instead of the opening picks?
I used a small standard screwdriver to "CAREFULL" separate the back plate. Suggest you have a can of air to clean the dust and crumbs off the motherboard
Christopher Suhre - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 47
crwdns2936753:030crwdne2936753:0 136
crwdns2942667:0crwdne2942667:0 2,692
