Acer Iconia Tab A500 Battery Replacement
  1. Acer Iconia Tab A500 Battery Replacement, Back Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To start, gently separate one corner of the case using the black spudger.
  2. Acer Iconia Tab A500 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
  3. Acer Iconia Tab A500 Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
  4. Acer Iconia Tab A500 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
crwdns2935229:09crwdne2935229:0
Kyle Libby
crwdns2935283:004/07/14crwdne2935283:0
1,006 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-23, Regan Spring 2014 crwdns2935289:0Cal Poly, Team 7-23, Regan Spring 2014crwdne2935289:0
CPSU-REGAN-S14S7G23
crwdns2935297:019crwdne2935297:0
I just replaced my battery because it kept draining and the new battery started to charge but now it won’t charger at all so what can be wrong?
misscris0611 - crwdns2934203:0crwdne2934203:0
Hi l have had my acer tablet for over 10 years and the acer iconiatab a500 as no been turned on for over 10 years and it is not cargering
Linda George - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 11,576
