Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement
  1. Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop to show the bottom side.
    • Remove the nine 6.5 mm screws using a JIS #1 screwdriver.
  2. Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a plastic opening tool to separate the outer casing and panel; gently work the tool around the entire outer edge
    • The easiest place to start is at one of the hinges. The corners can be somewhat difficult.
    • Be gentle. The internal clips can snap.
  3. Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel off the tape covering the wires.
  4. Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the battery from its studs, and place it closer to you.
    • The battery is not clamped or screwed onto the frame. Once you disconnect the battery, you are able to safely remove it by picking it up.
    • Unplug the rainbow wires connecting the battery to the motherboard.
    • Be sure to only grab the white portion of the plug, do not overstretch the rainbow wires.
    • Remove the battery from the laptop.
  5. Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement, Display Assembly: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement, Display Assembly: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 4.6 mm screws holding the left-side screen bracket to the internal components using a JIS #1 screwdriver.
  6. Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the bracket away from its original location.
  7. Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the clear tape securing the smaller wire.
    • Flip the small black clip securing the larger wire.
    • The wire below loosely sits inside the plug. It is fine if it comes out on its own after the clip is opened.
  8. Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the smaller wire.
    • Lift the larger wire, if it is still in place.
  9. Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the three 4.6 mm screws holding the right-side screen bracket to the internal components using a JIS #1 screwdriver.
    • Disconnect the ribbon cable from the motherboard.
    • There is only one wire on the right side. It's similar to the larger wire on the previous side, but slightly wider.
  10. Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 714 CP714-2W-56B2 Display Assembly Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the panel you've been working on.
    • Lift from the front edge of the panel, so that it and the screen form a 90 degree angle.
    • Pull the electrical panel straight back, away from the hinges/brackets. It shouldn't require any force.
Kristen Gismondi
crwdns2935283:011/12/14crwdne2935283:0
98,455 crwdns2915208:0crwdne2915208:0
crwdns2935297:0255crwdne2935297:0
crwdns2942667:0crwdne2942667:0 106
