Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement
  1. Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement, Back Cover: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Make sure the device is fully powered off.
    • Flip the computer over so that the back is facing up.
    • Remove the twelve 6mm Phillips #1 screws from the bottom of the laptop.
    Some of the screws are long and some are short - make sure you not which came out of which hold.
    Thomas Krauska - crwdns2934203:0crwdne2934203:0
    As always, I would recommend that you remember exactly where you remove the screws from, on this particular model, we did not see that the screws were different lengths. I would recommend sorting them in a pattern that is familiar, such as clockwise or counterclockwise. This way when replacing the screws you know exactly the order to put them back in.
    Evan Costa - crwdns2934203:0crwdne2934203:0
  2. Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the iFixit opening tools as wedges to pry the back of the laptop off.
    • Go slow, making sure not to snap the plastic. With enough of a gap made, you can use your hand to finish taking off the back.
  3. Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement, Display Screen: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement, Display Screen: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the five 6mm Phillips #1 screws from the hinges on either side of the laptop.
  4. Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the camera/microphone ribbon cable from the circuit board.
    • Remove the single 3mm Phillips #1 screw from the Intel core.
    • Unplug the cable from the circuit board.
    To unplug the camera/microphone ribbon cable from the circuit board, with your fingernail or the flat blade of a spudger, flip the cable clamp (the horizontal black plastic bar sitting atop the beige cradle) up from the top, as pictured, to release the cable. Then you can easily slide the ribbon cable out of its socket.
    JonnyLine - crwdns2934203:0crwdne2934203:0
  5. Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook Spin 15 CP315-1H-P1K8 Display Screen Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the plastic opening tool, create a gap between the back and front of the display.
    • Lift the front out with your hands.
Evan Costa
crwdns2935283:010/29/19crwdne2935283:0
506 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S4-G1, Saloman Fall 2019 crwdns2935289:0UMass Dartmouth, Team S4-G1, Saloman Fall 2019crwdne2935289:0
UMASSD-SALOMAN-F19S4G1
I just want to say that I’ve used this guide several times. My kid dropped the laptop and broke the hinge which is located inside the top cover behind the LCD panel. When this happened, it caused the grommets to come out of the plastic. But for about $45 we replaced the hinge and the top cover and I was able to fix it and put it all back together. I appreciate having this guide to remind me. Thank you!
Christopher Rayment - crwdns2934203:0crwdne2934203:0
Thank you so much for these instructions! The connections were the hardest part for me and the pictures were a great help.
Wendy Brooks - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,422
