Acer Chromebook CB5-571-C5XU Trackpad Replacement
  1. Acer Chromebook CB5-571-C5XU Trackpad Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB5-571-C5XU Trackpad Replacement, Bottom Case: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Trackpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB5-571-C5XU Trackpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Trackpad Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Trackpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Trackpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Gently lift the battery out and remove it from the laptop casing.
  6. Acer Chromebook CB5-571-C5XU Trackpad Replacement, Trackpad: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unhook the black ribbon from the motherboard, using the opening tool to pull the hooks in the direction of the arrows.
    • Once the hooks are released, simply pull the black ribbon outward to remove it from the motherboard.
  7. Acer Chromebook CB5-571-C5XU Trackpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB5-571-C5XU Trackpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Chromebook CB5-571-C5XU Trackpad Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #0 screwdriver, remove the 7 screws holding the trackpad in place.
    • The metal piece at the bottom edge of the laptop will lift off after the screws are removed.
  8. Acer Chromebook CB5-571-C5XU Trackpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the spudger tool to unhook the locks on both sides of the end of the white ribbon. Pull the ribbon outward away from the motherboard.
  9. Acer Chromebook CB5-571-C5XU Trackpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook CB5-571-C5XU Trackpad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger tool to pry the trackpad up and away from the laptop.
David Flint
crwdns2935283:010/17/17crwdne2935283:0
273 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S6-G1, Rockett Fall 2017 crwdns2935289:0UMass Dartmouth, Team S6-G1, Rockett Fall 2017crwdne2935289:0
UMASSD-ROCKETT-F17S6G1
How do I remove the touchpad from the backing/bracket? The replacement touchpad I bought has none of the metal bracket, and I believe I need to remove it from my old broken one.
Shawn H - crwdns2934203:0crwdne2934203:0
For the record I ended up having to purchase a new mounting bracket separately and affix it ($5). Hope this helps someone. I’ve done the repair but the trackpad is still not functioning. Not sure what the issue is but the swap was pretty easy.
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 362
