Acer Chromebook C710-2847 RAM Replacement
  1. Acer Chromebook C710-2847 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C710-2847 RAM Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the laptop on a flat surface with the bottom side facing up.
    • Place the tip of a spudger or finger into the hole on the battery release slider.
  2. Acer Chromebook C710-2847 RAM Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C710-2847 RAM Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the spudger to move the slider to the right and hold it there.
    • With the slider held, use your other hand to pull the battery back away from the laptop.
  3. Acer Chromebook C710-2847 RAM Replacement, Acer Chromebook C710-2847 Back Cover Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • This step will void your device warranty.
    • Use the screwdriver to pierce the warranty sticker.
    • Unscrew and remove the #0 6mm Phillips screw and set it aside.
    Bradley,
    If I replace the chrome os Hard drive with one that has a Linux distro already installed will the linux work normally or is there something built in to stop it.
    It's something I do with an old dell I use for checking out distros.
    Regards,
    Jack
    jack martin - crwdns2934203:0crwdne2934203:0
    I guess it's too late to answer this question now, but C710 is not IBM PC-compatible so standard linux distros do not run normally on it without any modifications.
    You can flash a IBM PC-compatible bootloader(coreboot+SEABIOS) on it to run other linux distros.
    cdac1234 -
    Any suggested source for getting the 4 Gb RAM upgrade? Does this RAM have a model number?
    rwells78 -
    What is the hard drive called, or it's specific name, so that I may search around for a replacement, before taking my laptop apart?
    Jennifer Munoz - crwdns2934203:0crwdne2934203:0
    Mine is a Seagate ST320L T020
    Marshall Gates -
    do not so what the second picture shows and leave the battery in!
    brayton1234567 - crwdns2934203:0crwdne2934203:0
  4. Acer Chromebook C710-2847 RAM Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C710-2847 RAM Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the back panel towards you. The best spots to place your fingers are on the bumpers.
    • Lift on the front edge to remove the panel.
  5. Acer Chromebook C710-2847 RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C710-2847 RAM Replacement, RAM: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the metal tabs sideways away from the memory stick.
    • The RAM stick will pop up.
  6. Acer Chromebook C710-2847 RAM Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Chromebook C710-2847 RAM Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the RAM stick up and away from the laptop.
    Who manufactured the chrome book C710 factory ram ?
    Meme bru - crwdns2934203:0crwdne2934203:0
crwdns2935229:013crwdne2935229:0
Bradley Pavy
crwdns2935283:009/30/13crwdne2935283:0
1.257 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-3, Forte Fall 2013 crwdns2935289:0Cal Poly, Team 13-3, Forte Fall 2013crwdne2935289:0
CPSU-FORTE-F13S13G3
crwdns2947412:07crwdne2947412:0
Is there only one RAM stick? My wife's C710 has 2 GB of RAM and I have two spare 2 GB sticks. I assumed that the C710 had two 1 GB sticks. Is this incorrect? Are two 2 GB sticks not going to help?
Garrett Mick - crwdns2934203:0crwdne2934203:0
I believe the C710 comes with a single stick of RAM preinstalled, but there are two slots there. So if you have the correct type of RAM, you should be good to go. One installs right on top of the other.
Jeff Suovanen -
Acer and Crucial insist that 4 GB is maximum ram, but I’ve successfully installed 12 GB and I’ve read reports on the web of 16 GB. It uses the same memory as my 2012 Mac Mini, (my source for the additional RAM) Adding a SSD will make this a powerful machine indeed. The main limitation is that although it will run the (aging) Chrubuntu (an Ubuntu install running on the Chrome kernel), it will not dual boot with linux. The firmware needs to be flashed in order to install a newer linux distro (Gallium OS or a specialized Mint 18), and this will effectively end it’s ability to run Chrome (although I beleive the firmware can be re-flashed so as to return it to Chrome OS .)
cuvtixo - crwdns2934203:0crwdne2934203:0
I want to change the ram stick up to 16 GB ram stick.
How?
flip - crwdns2934203:0crwdne2934203:0
What is the max RAM this laptop can take?
Austin Nickels - crwdns2934203:0crwdne2934203:0
Acer would only support 4GB total I believe, but there have been persistent reports of 16GB being possible. You have to remember that every other Acer Chromebook, and all other brands at this time had soldered-on RAM, and, hard drives that could not be upgraded (I believe the C720 had eMMC "SSD", none of the other Chromebooks had SATA. It wasn't until the premium model of the Pixelbook came out in 2017 that another Chromebook had 16GB (the two other models that year had 8GB). The C710 was a very special Chromebook, so its difficult to say if it can fully take advantage of two 8GB RAM for sure.
cuvtixo -
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 13,403
