Acer Aspire V5-572, V5-572G Mainboard Replacement
crwdns2936621:0crwdne2936621:0
  1. Acer Aspire V5-572, V5-572G Mainboard Replacement, Bottom Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Mainboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Mainboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572, V5-572G Mainboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572, V5-572G Mainboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
    Love the tutorial man...but this is the most moronic thing I've ever seen...you can take batery out of laptop 15 years old in a flash, while here you have to disassemble the whole %#*@ laptop...only idiots can come up with something like that
    razbojnikkuro - crwdns2934203:0crwdne2934203:0
    I have to agree that this is extremely complicated and intense.
    There is no way your average user should be doing this and the average user should be able to replace the battery!!
    Like everything in the computer world, hardware or software, ease of use is no longer even a consideration!!
    Technical Support Bots are the rule and they rarely are up to date with the pages on the website!!
    Sucks!!
    andy.cox - crwdns2934203:0crwdne2934203:0
  4. Acer Aspire V5-572, V5-572G Mainboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Mainboard Replacement, Battery: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the single Phillips 0 screw securing the battery.
  6. Acer Aspire V5-572, V5-572G Mainboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery
    How much will cost me a replacement battery?
    Anthony Borg - crwdns2934203:0crwdne2934203:0
  7. Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572, V5-572G Mainboard Replacement, HDD: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the SATA Cable from the Mother Board.
    • Take out the HDD and remove the SATA cable from it.
    • Now you can change / upgrade your HDD.
  8. Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572, V5-572G Mainboard Replacement, Wi-Fi half mini PCIe card: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove 1x screw and disconnect the two antenna coaxial cables.
    • Remove the Wi-Fi card from the slot.
  9. Acer Aspire V5-572, V5-572G Mainboard Replacement, Cooling / Fan System: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire V5-572, V5-572G Mainboard Replacement, Cooling / Fan System: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the Fan cable.
    • Remove the three screws from the CPU cooler and one from the Fan module.
    • When you change the Cooling system, you must clean the processor from old thermal compound and put new.
  10. Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572, V5-572G Mainboard Replacement, Mainboard: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect one by one:
    • LCD Display flex cable
    • DC Jack cable
    • USB Board flex cable
    • Touch pad flex cable
    • Keyboard flex cable
    Ich hatte Probleme beim Entfernen des “USB Board flex cable”. Man muss vorsichtig den weissen “Schließer” in Richtung Kabel etwas öffnen. Nicht ganz herausziehen (obwohl das sehr leicht passiert). Das Kabel muss sich leicht herausziehen lassen. Beim Zusammenbau dann umgekehrt: Zuerst das Kabel einstecken, dann vorsichtig den Schließer wieder eindrücken.
    Michael Klüting - crwdns2934203:0crwdne2934203:0
  11. Acer Aspire V5-572, V5-572G Mainboard Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572, V5-572G Mainboard Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572, V5-572G Mainboard Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Disconnect the Loudspeakers and the Microphone cables.
    • Remove 6x Phillips screws, 3x from the Main board and 3x from the hinge.
    • Open a little the laptop to open the hinge.
    • By hand, open the hinge to the end.
  12. Acer Aspire V5-572, V5-572G Mainboard Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572, V5-572G Mainboard Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire V5-572, V5-572G Mainboard Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully remove the the Main board.
ZFix
crwdns2935283:012/09/13crwdne2935283:0
194 715 crwdns2915208:0crwdne2915208:0
crwdns2935297:0330crwdne2935297:0
Master Techs crwdns2935289:0Master Techscrwdne2935289:0
Community
crwdns2931471:0326crwdne2931471:0
crwdns2935297:01 377crwdne2935297:0
where did you find your motherboard replacement? Or whats model is it? I need to replace my mb but cant find any online for sale.
Ruby - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 4,843
