Acer Aspire TimelineX 4830T-6682 Battery Replacement
  1. Acer Aspire TimelineX 4830T-6682 Battery Replacement, Lower Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Battery Replacement, Lower Back Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Battery Replacement, Lower Back Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the single screw with a Phillips #0 screwdriver.
    • Use a plastic opening tool on the upper part of the panel to remove it and access the RAM.
    • The other way to remove the panel is by sliding it away from the laptop. The difficulty of sliding it depends on the condition of your laptop.
    This was gr8! What would we do without ifixit?! Thanks!
    pendarvis brooklyn - crwdns2934203:0crwdne2934203:0
  2. Acer Aspire TimelineX 4830T-6682 Battery Replacement, RAM: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Battery Replacement, RAM: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Battery Replacement, RAM: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • After the panel has been removed, locate the RAM. It should be on the lower right.
    • There are pins around the RAM that need to be pulled back. After the pins are removed, pull the RAM chip towards you to remove it.
  3. Acer Aspire TimelineX 4830T-6682 Battery Replacement, Keyboard: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the eleven screws that hold that back panel to the laptop using a J0 Phillips screwdriver bit.
  4. Acer Aspire TimelineX 4830T-6682 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    $3.99
    • Place the laptop in the upright position, the lower front touchpad panel should be easily detatched at this point.
    • Remove the lower front touchpad panel by using an angled tweezers to disconnect the only wired tape connected to the motherboard.
  5. Acer Aspire TimelineX 4830T-6682 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Next, disconnect the 4 wired tapes of the keyboard from the motherboard just like we did with the lower front touchpad panel.
    At this step 3 additianal screws have to be removed on the lower left, middle and right side (which are also visible on the image but not marked) before the keyboard cover can be removed!
    Robert - crwdns2934203:0crwdne2934203:0
  6. Acer Aspire TimelineX 4830T-6682 Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Finally, using an opening tool, gently pry along the edge of the keyboard to separate it from the laptop.
  7. Acer Aspire TimelineX 4830T-6682 Battery Replacement, Battery: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The battery will be on the side closest to the screen.
    • Gently lift it out. It will still be attached by white, red, and black wires.
  8. Acer Aspire TimelineX 4830T-6682 Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire TimelineX 4830T-6682 Battery Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull the white plug, it should easily detach.
    • Remove the battery from the device.
    There are 3 screws holding the keyboard that need to be removed. One at the small ribbon on the left; one at the large ribbon on the right and one in the centre of these two. This step is not shown in the teardown. Failure to do this will damage the keyboard
    Wombat - crwdns2934203:0crwdne2934203:0
To reassemble your device, follow these instructions in reverse order. When reattaching the back panel, make sure to pry out the pwr on/off slide switch near the center. The back panel switches it off when closing, and there is no other way to avoid it.
Rachel Wagner
crwdns2935283:009/25/17crwdne2935283:0
277 crwdns2915208:0crwdne2915208:0
University of North Texas, Team S3-G6, Thompson Fall 2017 crwdns2935289:0University of North Texas, Team S3-G6, Thompson Fall 2017crwdne2935289:0
UNT-THOMPSON-F17S3G6
Great instructions but there is one step missing. There are three more screws holding the key board on. Once you remove the mouse they are under that part. Other than that thanks.
Chris Webber - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 5,826
