Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement
  1. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement, Touchpad: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Driver with the Phillips PH0 attachment to unscrew the 7 5mm screws from the back panel.
    • This screw does not need to be removed because it doesn't hold the backplate in.
  2. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Push the plastic opening tool into the crevice between the front and back panel.
    • Pull down on the plastic opening tool like a lever to create space and slide along the crevice to remove the back panel.
  3. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently slide the plastic opening tool under the black clip that is attached to the ribbon cable.
    • Pull down on the plastic opening tool like a lever to flip the black clip and remove the ribbon cable.
    • The black clip doesn't take much force to lift, so be gentle to avoid breaking it.
  4. Acer Aspire Switch 10 SW5-011-18R3 Track pad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the touchpad.
Max Francois
crwdns2935283:009/28/16crwdne2935283:0
684 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 3-4, Passmore Fall 2016 crwdns2935289:0USF Tampa, Team 3-4, Passmore Fall 2016crwdne2935289:0
USFT-PASSMORE-F16S3G4
Thank you for the steps. I want to know if a replacement keyboard is available in the market. I did not find online.
Gibson Castelino - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 1,660
