Acer Aspire R5-571T-59DC Battery Replacement
  1. Acer Aspire R5-571T-59DC Battery Replacement, Back Cover Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire R5-571T-59DC Battery Replacement, Back Cover Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect all power from the laptop and turn over so the bottom is facing you.
    • Remove the twelve 07.mm Phillips #0 screws from the back cover.
    • Work a plastic opening tool underneath and around the perimeter of the bottom cover.
    • Once unclipped, remove the bottom cover.
    What's the best way to safely remove and replace the bottom cover to prevent bending and otherwise stressing the casing and ports as you wiggle it loose and set it back in place?
    Alberto Einsteino - crwdns2934203:0crwdne2934203:0
  2. Acer Aspire R5-571T-59DC Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire R5-571T-59DC Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire R5-571T-59DC Battery Replacement, Battery: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the two 0.7mm Phillips #00 screws from the battery and unplug the battery from the motherboard.
    • Lift the battery out of the case.
Kelly Johnston
crwdns2935283:001/25/18crwdne2935283:0
600 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S20-G2, Passmore Spring 2018 crwdns2935289:0USF Tampa, Team S20-G2, Passmore Spring 2018crwdne2935289:0
USFT-PASSMORE-S18S20G2
This seems to be the correct battery for the replacement, judging by the above photos, the AC14B3K
Acer AC14B3K, AC14B8J, and AC14B8K Laptop Battery
I plan to try this repair myself soon.
Sean Anderson - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 5,219
