Acer Aspire Go 15 AG15-31P-3947 Speakers Replacement
  1. Acer Aspire Go 15 AG15-31P-3947 Speakers Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Speakers Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, power off your device completely and disconnect from the charging adapter.
    • Flip the laptop over so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove ten 5.6 mm screws from the back panel.
    • Place the end of an opening tool in the seam between the bottom and top case and slide it around the perimeter to release the clips holding it together.
    • Use a few opening picks in the seam to keep the clips from reattaching.
    • Remove the back panel.
  2. Acer Aspire Go 15 AG15-31P-3947 Speakers Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Speakers Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Speakers Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket on the motherboard.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
    • Lift the battery upwards to remove it from the device.
  3. Acer Aspire Go 15 AG15-31P-3947 Speakers Replacement, Speakers: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Speakers Replacement, Speakers: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To disconnect the speaker cable, use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket.
    • Don't pull on the cables.
  4. Acer Aspire Go 15 AG15-31P-3947 Speakers Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Speakers Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Speakers Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently remove the speaker wire from routing guides.
    • The wire may also be attached to the chassis with adhesive.
    • Remove the speakers and wire that connects them from the laptop.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Knicholas Taylor
crwdns2935283:002/10/25crwdne2935283:0
181 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-5, Kilpatrick Spring 2025 crwdns2935289:0University of North Texas, Team 1-5, Kilpatrick Spring 2025crwdne2935289:0
UNT-KILPATRICK-S25S1G5
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 53
