Acer Aspire Go 15 AG15-31P-3947 Fan Replacement
  1. Acer Aspire Go 15 AG15-31P-3947 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, power off your device completely and disconnect from the charging adapter.
    • Flip the laptop over so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove ten 5.6 mm screws from the back panel.
    • Place the end of an opening tool in the seam between the bottom and top case and slide it around the perimeter to release the clips holding it together.
    • Use a few opening picks in the seam to keep the clips from reattaching.
    • Remove the back panel.
  2. Acer Aspire Go 15 AG15-31P-3947 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket on the motherboard.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
    • Lift the battery upwards to remove it from the device.
  3. Acer Aspire Go 15 AG15-31P-3947 Fan Replacement, Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Fan Replacement, Fan: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the end of a spudger to push on alternating sides of the sliding connector and remove it from the socket on the motherboard.
  4. Acer Aspire Go 15 AG15-31P-3947 Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Fan Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws attaching the fan to the chassis.
    • Slide the fan out from the socket to remove it.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Alijah Sanchez
crwdns2935283:009/13/23crwdne2935283:0
335 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-5, Kilpatrick Spring 2025 crwdns2935289:0University of North Texas, Team 1-5, Kilpatrick Spring 2025crwdne2935289:0
UNT-KILPATRICK-S25S1G5
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 58
