Acer Aspire Go 15 AG15-31P-3947 Battery Replacement
  1. Acer Aspire Go 15 AG15-31P-3947 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before you begin, power off your device completely and disconnect from the charging adapter.
    • Flip the laptop over so the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove ten 5.6 mm screws from the back panel.
    • Place the end of an opening tool in the seam between the bottom and top case and slide it around the perimeter to release the clips holding it together.
    • Use a few opening picks in the seam to keep the clips from reattaching.
    • Remove the back panel.
  2. Acer Aspire Go 15 AG15-31P-3947 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire Go 15 AG15-31P-3947 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the point of a spudger to push on alternating sides of the battery connector to "walk" it out of its socket on the motherboard.
    • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
    • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
    • Don't push on the cables themselves, or you may damage the connector.
    • Lift the battery upwards to remove it from the device.
To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery after completing this guide.
Griffith Fitzgerald
crwdns2935283:002/10/25crwdne2935283:0
88 crwdns2915208:0crwdne2915208:0
University of North Texas, Team 1-5, Kilpatrick Spring 2025 crwdns2935289:0University of North Texas, Team 1-5, Kilpatrick Spring 2025crwdne2935289:0
UNT-KILPATRICK-S25S1G5
crwdns2936753:030crwdne2936753:0 49
crwdns2942667:0crwdne2942667:0 189
