If you have battery problems or need to remove your battery before replacing other parts of the laptop, use this guide to remove and replace your battery.
Turn off the laptop and disconnect all device cords.
Flip the laptop over so the bottom is facing you.
Use your finger or a spuger to pull the battery release switch.
For optimal performance, after completing this guide, calibrate your newly installed battery.
