Acer Aspire A515-51G Battery Replacement
  1. Acer Aspire A515-51G Battery Replacement, Unfasten the HDD hatch: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Unfasten the HDD hatch: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the screw securing the HDD hatch on the bottom left of the lower case.
  2. Acer Aspire A515-51G Battery Replacement, Remove the HDD hatch: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Remove the HDD hatch: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Remove the HDD hatch: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the flat end of a spudger under the cutout on the top right corner of the HDD hatch and pry it up.
    • Remove the HDD hatch.
  3. Acer Aspire A515-51G Battery Replacement, Unfasten the HDD assembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Unfasten the HDD assembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Your HDD assembly may be secured to the lower case with screws. If it's not, skip this step.
    • Use a Phillips screwdriver to remove the four screws securing the HDD assembly.
  4. Acer Aspire A515-51G Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire A515-51G Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire A515-51G Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Firmly grip the HDD assembly and HDD cable connector head.
    • Pull the HDD cable connector out of its socket.
    • Remove the HDD assembly.
  5. Acer Aspire A515-51G Battery Replacement, Unfasten the lower case: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Unfasten the lower case: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the eighteen 6.6 mm screws securing the case.
  6. Acer Aspire A515-51G Battery Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Insert an opening pick: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  7. Acer Aspire A515-51G Battery Replacement, Release the case's front clips: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Release the case's front clips: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Release the case's front clips: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Slide the pick along the front edge to release the clips securing the lower case.
  8. Acer Aspire A515-51G Battery Replacement, Release the remaining clips: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Release the remaining clips: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  9. Acer Aspire A515-51G Battery Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire A515-51G Battery Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire A515-51G Battery Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  10. Acer Aspire A515-51G Battery Replacement, Disconnect the battery: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Disconnect the battery: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Disconnect the battery: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  11. Acer Aspire A515-51G Battery Replacement, Remove the tape: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Remove the tape: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use tweezers, or your fingers, to peel back the tape connecting the battery to the motherboard.
  12. Acer Aspire A515-51G Battery Replacement, Unfasten the battery: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Unfasten the battery: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a Phillips screwdriver to remove the two 4.5 mm-long screws securing the battery.
  13. Acer Aspire A515-51G Battery Replacement, Remove the battery: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Remove the battery: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Acer Aspire A515-51G Battery Replacement, Remove the battery: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the battery towards the top of the laptop to release its plastic clips.
    • Remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
crwdns2935283:001/16/22crwdne2935283:0
166.156 crwdns2915208:0crwdne2915208:0
crwdns2935297:0769crwdne2935297:0
Staff
crwdns2931471:0120crwdne2931471:0
crwdns2935297:020.086crwdne2935297:0
Where would you suggest going to buy a replacement battery for this A515-51G model Acer laptop?
Howard Rees - crwdns2934203:0crwdne2934203:0
crwdns2936751:024crwdne2936751:0 11
crwdns2936753:07crwdne2936753:0 83
crwdns2936753:030crwdne2936753:0 450
crwdns2942667:0crwdne2942667:0 5,500
